Expert
- Posted on Mar 02, 2008
Re: Does not turn on properly
Firmware manager should solve this problem.
First Make sure that you have your PC connected to the internet, as the firmware manager will download the firmware from the firmware server, it is necessary that you have the PC online during the entire the process.
Run the application on your PC at Start->Programs->Philips Firmware Manager->Philips Firmware Manger.
Connect the GoGear player with the PC in normal mode. Switch on the player.
Firmware Manager will start the upgrade process after the player is detected.
Enter the serial number of your device. You can find the serial number as a 14 digital code printed on the sticker near the USB connector of the device e.g. SFxxxxxxxxxxxx and then click NEXT to proceed.
Click the START button, select the firmware and click OK.
The upgrade process will continue to download firmware.
Once the upgrade process is completed, click FINISH to close the application.
You may now disconnect the GoGear Player from your computer.
