Computers & Internet Logo
Posted on Feb 26, 2010
Display become blur when switch on
Laptop display become blur when switch on
Anonymous
Level 1:
New Friend:
  • Contributor 52 Answers
  • Posted on Feb 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
52
Questions
0
Helped
10279
Points
94
Your disply cable or LCD faulty replace it
1helpful
Blaupunkt tv screen blurred on righthand side for like 2 inches top to bottom. Any ideas?
A blurred screen on the right-hand side of a Blaupunkt TV for about 2 inches from top to bottom can be caused by a few different issues, such as:
  1. A problem with the display panel: The display panel may have become damaged or malfunctioned, causing the blur on the right-hand side of the screen.
  2. A problem with the T-CON board: The T-CON board controls the video signal between the main board and the display panel. If it is not working properly, it can cause the blur on the right-hand side of the screen.
  3. A problem with the main board: The main board controls the various functions of the TV. If it is not working properly, it can cause the blur on the right-hand side of the screen.
  4. A problem with the cable or connector: Damaged or loose cable or connector can cause the blur on the right-hand side of the screen.
It's best to consult the manual or a professional technician for help. They will be able to diagnose the problem and recommend the appropriate course of action. Sometimes, the problem can be solved by replacing a faulty module, repairing or replacing damaged cable or connector, but in some cases the repair may be more complex and require more extensive work.
Dell laptop display
This can be one of two things. The first is unlikely, the display cable has become loose. The second is more possible, the screen has gone bad and needs to be replaced.
The display on my hp laptop has become blurred and out of focus, i have adjusted the settings on the "personalise" option but it remains blurred. Is there anything I can do about this?
Good Morning.
This could be a hardware issue, releated to Video card of the Laptop.
Please try updating the BIOS of the Laptop, this may fix the issue, if still the issue persists, then this a hardware issue. Could be with LCD display or video card.
To update the bios, please refer the link below.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01056794&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
This should fix the issue.
1helpful
Help Me Please...my Toshiba A45-S151 Screen become garbled, seems like my LCD lost its black color....the screen display blur line,, and has no black colour.... it happens after i dissamsembly my laptop
Check the Wire Harness make sure it is back in the correct place and plugged in all the way into its designated plug. :) also, if that doesnt work then you can replace the LCD. Which is expensive.
2helpful
2answers
I have Compaq V6000 series laptop with AMD Processor & nvidia graphic card ,my laptop?s lower half of screen becomes blurred & will become ok after some adjustments & again become blurred when...
There was a TSB about the motherboards on the V series describing severe video issues and Nvidia GPU failures. Many consumers got a motherboard replacement. Try using a laptop cooler in the meantime and see if that helps a little. Also try googling V6000 video and see how many others got nuked by this poor design.
Screeen is blurred
are u using built in or external graphics . are the drivers fully upto date ??
Picture blur display
If the picture shrinks and expands you can get a repair kit from www.tvrepairkits.com.
If the screen is just foggy looking my guess is the CRT fluid needs to be replaced.
2answers
My graphic become blur
You need to switch it to 32-bit, not 16 bit. DX9 drivers shouldn't be an issue, but if all else fails re-installing you video card drivers might help.
Hope that helps,
erch.
My compaq m2000 has problem with display
I have a Diagram of the Switch and some more info and tips on my Website re LCD Screens and troubleshooting. It could be worth Up dateing Your Bios and Your Graphics Drivers.
more info at: www.powerjackrepair.com
Hope this helps
Lens assembly
"Lens Error" requires to be sent into repairs.
Grand Canyon Tech
Grand Canyon Tech
