Find water demineraliser -water clean product for steam iron
Any undersink reverse osmosis system will give you the low tds high quality water needed for the steamer. Make sure the ro system does not have a mineral cartridge to add back calcium that it removes from water.
You can use cheap pure distilled water (with no additive) as used to top up car battery: supermarkets and auto shops will carry the product.
You can also make your own by investing in a water distiller but they can be expensive and the cheaper model will take about one hour to make one liter.
As a cheap alternative and easy to find alternative, use a good quality drinking water filter (jug) to make your clean product with tap water and your steam iron will still thank you!
Hope it helps!
1 Fill the iron's steam receptacle with white vinegar or CLR, a product used to clean coffee pots. CLR is available in department stores.
