Canon PIXMA  iP1800 InkJet Photo Printer Logo
Posted on Feb 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My printer is Canon PIXMA iP1900. It has a paper jam problem, I couldnot find any paper in it. I cannot use it now. Can you help
Anonymous
Level 2:
Sniper:
  • Expert 56 Answers
  • Posted on Mar 01, 2010
Anonymous
Expert
Level 2:
Sniper:
Answers
56
Questions
Helped
41330
Points
218
Hai there...i think your printer have something stuck from inside....check your roller if anything stuck there....
I have a Canon Pixma iP1900, it will initially grab the paper but then the paper will just stop but the printer will continue while the paper doesn't move. Then when I cancel the printing it tells me that...
Hello -
From Support information I found on the Canon website, the paper feed rollers of your PIXMA iP1900 may need cleaning.
Source:
https://www.canon.co.uk/support/consumer_products/content/faq/?itemid=tcm:14-609974
The feed roller cleaning function allows you to ckean the paper feed roller. perform feed roller cleantng when there are paper particles sticking to the paper feed roller and paper is not fed properly.
The procedure for cleaning the feed rollers is as follows:
1.Prepare the printer
Remove all sheets of paper from the rear tray.
2.Open the printer driver setup window
3.Click Roller Cleaning on the Maintenance tab
The confirmation message appears.
4.Execute paper feed roller cleaning
Make sure that the printer is on and click OK.
Paper feed roller cleaning starts.
5.Complete paper feed roller cleaning
After the rollers have stopped, follow the instruction in the message, load three sheets of plain paper into the rear tray, and click OK.
Paper will be ejected and feed roller cleaning will be completed.
Best wishes.
2answers
Help me fix my paper jam
canon pixma mx 452 paper jam fix
Canon pixma ip1900 paper jam
Hi
Here's a few things you can try :-
1. Blow it out with canned air. make sure there are no bits of paper or dust in the paper feed area and in the front access area that could be causing the jam.
2. Verify that the cartridge carriage moves to the service area when the front door is opened (as if to change tanks)
3. Verify that the timing belt, drive belt, gearing and rollers all look normal.
4. Take the network out of play when doing the initial troubleshooting
5. With the computer off, unplug the printer's power cord and USB cord for about 3-5 min
6. Completely uninstall the printer's driver and software. Then reinstall the printer's drivers only.
Retry after each step.
Also if your Canon printer has fax capabilities, and you are getting a false paper jam error, the problem is easy to fix.
Open the scanner lid.
You will see a white strip on the left, under the lid.
There are also two small, white tabs near this strip.
Gently pull on each tab. You should feel a small "click" on the tab that is jammed.
This fixes the problem.
I suspect that when previously scanning something like a book page, one of these tabs got pushed the wrong way.
Hope it will help.Also you can get back to me if you need further assistance.
Thankyou.
5helpful
Resetter of canon iP1900
Step 1 : Reset Hardware
  1. Turn off Canon Pixma iP1900, iP1300 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the Canon Pixma iP1900, iP1300 Printers should turn off, if not, press the Power button once more.
  8. Your Canon Pixma iP1900, iP1300 Printers should respond as normal
2helpful
The CD ROM for my Canon Pixma ip1900 is missing
Alternatively, you can download the Drivers & Software for Canon Pixma IP1900
Visit above Canon Official link to get the required drivers and utilities.
CreativeTECH
2answers
I got an error with my canon ip1900 it says "paper jammed" i press Resume but nothings happen it's just repeating the error "paper jammed" what i need to do?
You need to open the printer and remove any piece of paper no matter how small. This can be causeed by even a small sliver of paper or even paper dust. It can also be the paper sensor but thats very uncommon.
Take the paper out fan and restack it. Then open up the printer and clean it as best you can. Put everything back in and close it up and you should be printing.
16helpful
4answers
My canon ip1900 says paper jam, gives 3 orange flashes and 1 green flash .cant find any paper jam?
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
2helpful
Canon iP1900 paper jam error
Use this Ip Tool,
Reset your printer.
First:Find the model on the tab, then reset the black and color,after that reset the platen and main, and finally reset the EEPROM.
Hope it works!!!
2answers
Canon Pixma mx300 printer has paper jam message.
Canon Pixma MX300
- new cartrige for Black ink
- can scan
- can photocopy documents
BUT can't print documents from my MacBook eventhough the paper feeds and goes out at the other side
old marine
old marine
ZJ Limited
ZJ Limited
