Have the ink system failure on my hp printer...
need help ?
ruth
I found this on the web. Should clear up problem.
If you find this information helpful, pls rate me.
It is a good forum., for all types of problems.
http://www.fixyourownprinter.com/forums/printer/50063
Christina: Let us perform some steps to isolate the issue and find a fix for it.
Christina: Please perform the following steps and let me know the message that will be displayed on the printer.
Christina: A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
CustomerName: ok
CustomerName: screen says "support" R0631M
Christina: Fine.
Christina: 2. Press and release the right arrow button until the display says “System Configuration Menu”.
Christina: 3. Press and release the “OK” button.
Christina: 4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
Christina: 5. Press and release the “OK” button.
Christina: 6. Display should say “Hardware failure status: Clear. Press OK to clear”.
CustomerName: yup
Christina: 7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
CustomerName: ok
Christina: 8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
CustomerName: ok
Christina: 9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
CustomerName: done
Christina: Fine.
Christina: 10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
CustomerName: done
Christina: 11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
CustomerName: made a buncha noise, and it didn't print a diagnostic page
Christina: Good.
Christina: Is the error message still being displayed on the printer?
CustomerName: nope
Christina: Good.
CustomerName: should I try to print something?
Christina: Let us print a self test page to check the functionality of the printer.
Christina: Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
Good Luck.
Check out this Thread about Ink system failure.
Ink System Failure Forums <--- Click here
SOURCE: HP ERROR CODE 0XC18A0401
There is one fix for the 0x errors and it doesn't always work but this is the only option.
Press and hold the "*" key. Press the "#" key and release both keys.
Display should say "Enter Special Key Combo"
Press and release in sequence the "1", "2" and "3" buttons.
Display should say "Support" and display the FW rev (something like R0631R)
Mine reads R0631M
. Press and release the right arrow button until the display says "System Configuration Menu".
Press and release the "OK" button.
Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",
Display should say "Hardware failure status: Clear. Press OK to clear".
Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer.
Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
SOURCE: error 0xc18a0401
This can be a failure of the firmware which means the printer is in hardware failure status but it can sometimes be fixed. Follow these steps EXACTLY as written.
Press and hold the “*” key. Press the “#” key and release both keys.
Press and release in sequence the "1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
Mine reads R0631M
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
