I have a Maytag Quiet Series 300 and the top rack dishes dont get clean. Water doesn't appear to be coming out of the upper tray spray arm. I took that arm apart as best I could and cleaned it out. I can blow through it easily. I also tried switching the position of the upper and middle trays and which ever tray is in the top position does not spray...Any ideas? is there a seperate pump for the upper spray arm?
Hey- Two things could be wrong.- clog, or bad motor. Sump screen needs to be cleaned of debris. Removal of sump cover to access screen requires torx bits and some patience. Replacement of pump requires pulling out dishwasher to access bottom. Motors fail when seal between motor and pump fails. Will still operate, but become weaker over time. Parts available- motor about 100$ at appliance parts pros.appliancepartspros. Hopes this helps- Thanks- ED
