Press and hold Fn then tap arrow up until screen brightens if it fails, turn off comp press and hold D and press power, it will perform Built in self test on LCD
I'm sure you haven't used all printers. Anyway, are you printing color images such as pictures, etc. If so try using a glossy paper. The colors and images are much more true colors on glossy paper, and it don't **** up your ink.
When the TV is on, if you look at the screen and can see dark images, then you will need to replace both the inverters.The inverters drive/power the back light inside the LCD to show the images.You may have to try and different channels and or inputs to truly see if you can see dark images while the TV is on.If you are hearing audio from a channel or an input then you should be able to see the dark images if just the inverters are bad.
If the screen is dead black without any dark images, then typically your LCD screen/module is bad.
If the TV powers up (power supply is good), you have audio and the remote will work with the TV (the main board is good), the only parts left is the inverters or the LCD screen/module.
I can get you LG part numbers if you need them.
Dark as in gone or dark as in the image is still viewable? How does the onscreen menu look when the image is dark/gone? If the onscreen menu looks right and the image is still dark, you might want to check the cables or another input. If another device using different cables and another input looks fine, you may only have a problem with the input/cable you are using to view the movie. If the onscreen menu is also dark, then I would think there is an internal problem that needs looking into.
Adjust the brightness of the screen using the Camera SETUP menu. See page 3-14 for instructions. In direct sunlight conditions, you may need to shield the LCD display monitor with your hand.
