Kenmore HE2 Plus Front Load Washer Logo
Posted on Feb 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F21 CODE ON DISPLAY WONT GO THRU A CYCLE JUST MAKES A HUMMING NOISE FOR A BIT THEN THE F21 CODE COMES ON.
Anonymous
Level 3:
  • Master 5,911 Answers
  • Posted on Feb 26, 2010
Anonymous
Master
Level 3:
Answers
5911
Questions
6
Helped
2734231
Points
22413
If this is a Kenmore Elite front loading series washer, "F21" is a Long Drain error code. This indicates that you have an obstruction somewhere in the drainage system. Most commonly, this means there is something lodged in the drain pump or inlet line running from the wash tub to the pump. There is a white screw off cap on the drain pump that you can remove to inspect the pump impeller and clean. The following link explains:
http://www.fixya.com/support/r3608588-f21_error_code
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing such as socks or under garments can commonly clog in this area as well causing the drain cycle to fail.
NOTE: A "SUD" error code can often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error (if displayed) should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
03 toyota corolla wont start makes humming noise
Sounds like your starter has failed, what your probably hearing is the solenoid trying to engage. Have the starter checked.
7helpful
2answers
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Water will not drain humming noise
Humming sound could be jammed pump.Remove th filter and check pump Blades are free, nothing is stuck in it....
No water running through cycle once filled....making humming noise once clicks into cycle
pump should be checked for restriction of movement,is there something blocking it?does the capacitor smell?if it does its blown(or meter check-more accurate),hope this helps
Spray arm light comes on also cycle comes to a hault
Electronics module , time to replace. Vitally
May 12, 2009 • Dishwashers
Code E20
my cloths will wash but will not spin out the drum stop turning when it comes to the spin cycle makes a humming noise
Wash Cycle Noise
you can chat with me now!
fault may be more simple than replacing the whole circ pump. it is probably the pump capacitor which is a cheap part. no need to buy as a bosch spare - you should be able to find a capacitor of the right value from a good elec spares shop. value is printed on the capacitor
Alexander
vince
