Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer sd-532hds. the red light is on but when
Pioneer sd-532hds. the red light is on but when trying to turn on nothing happens. I was watching the tv when a pop happened and the t went off. looked in the backand checked the fuses and the looked good. Is it worth repairing?
  • Rebecca Aug 07, 2011
    I think we had same problem cat sat on remote and all of a sudden pop tv just shut off and when we tried to turn it back on it won't it tries to go green on power light and then automatically shuts back off never getting picture don't know anything about fixing tvs just scowered internet for a solution husband opened panel in back to see if there was a reset or a fuse but we don't know what to replace or what to get fuse, powerboard?? please help
  • Pioneer Master
  • 5,138 Answers
STK ICS 2 of them replace Both STK392-110 use 180s Mats Electronics has them $10.95 each
1-800-628-1118
Posted on Feb 25, 2010
  • scatton55 Nov 21, 2010
    This sounds like my problem TV will run for about 20 minutes them a loud pop and it turns off. Not sure what this part is you are saying to replace. Could you be more specific?
  • ladywinn
    ladywinn Nov 22, 2010
    Loud pop could be coming from one of the anode buttons on one of the Picture tubes
    you need to first remove back and watch where the arking is coming from if the TV will come back on if not,. On the power supply board that has the FBT flyback transfomer their is a 6.3amp fuse look to see if it is blow. CK the Pico fuses they will look like resistor but are green or yellow 5amps 6amps 7amp pico fuse, let me know if you should need more help.
SOURCE:
Pioneer Rear Projection TV problems
a 240 ac voltage appliance will run happily on 220 volts but ther is obviously a fault as the green spark was possibly a fuse blowing
ie main fuse as power is not reaching the tv
Aug 14, 2012 | Pioneer SD-533HD5 53" Rear Projection HDTV
My SD-P6093-K Pioneer has recently stopped turning on. It makes a click noise as if it was turning on, but about 3 seconds later it makes another click noise and then then nothing. No picture no anything....
STK ICs 2 of them,example STK392-110.also CK hori out put transistor and little blue capacitor 2Kvolts it feeds back to Hori Transistor. Mats has STKs
1-800-628-1118 $10.95 each they retail for $55.00 each in repair shops.
Mar 16, 2010 | Pioneer SD-P62A3-K 62" Rear Projection...
Sd-p55a3-k/kc this tv does not turn on
Th convergance amps have failed you will half to replace them, or have it done parts are around 70 dollars not and easy fix on a pioneer time consuming
Dec 10, 2009 | Pioneer SD-P55A3-K 55" Rear Projection...
Pioneer sd-582hd5 shuts off while watching
internal components probably need to be cleaned.... sounds like a problem with t.v. overheating
Jul 11, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer SD-P5181 will not power up
pioneer sd p5181 will not power up redlight on stand by works when i hit the power button makes a funny sound and then nothing anyone plz!!!! help thnks
Jul 11, 2009 | Pioneer Televison & Video
55" PIONEER SD-P5795W REAR..
yeah, I have the same issue... The tv worked fine, and now it will not turn on... the light turns green, then turns off and goes red...
Aug 03, 2008 | Pioneer SD-P5795W 57" Rear Projection...
Pioneer projection blurry picture
Sounds like you lost the converigence. Have you tried to realign the convergence through the user menu? Try that first and see what happens.
Jul 20, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Plz help
remove the SD Card and the batteries. Wait for half an hour and then insert two new batteries. Do not put the SD card in as yet. (Waiting for half an hour or more allows the camera to reset itself).
Now try switching on and good luck.
Dec 27, 2007 | Kodak EasyShare C653 Digital Camera
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
633 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
