Right click on the .exe file, go to the compatibility tab and select an inferior operating system. Apply, Ok and it should work properly
Nope, I have Windows 7 and it won't even let me install it, before setup it says 'O.S. not supported'
yes it does
say that
How do i get to the .exe file
run the Installer in Compatability mode for Windows XP SP3, as that will run both the installer and the game fairly well.
Right click the installer, so to 'Properties' then go to the Compatibility tab, and run the Installer in Compatability mode for Windows XP SP3
Thanks guys, that really help me alot ow you one.
SOURCE: i wanted 18 wheels of
Hello suttonplaya3,
The game may work natively on Windows 7. If not you could try to run it using Windows XP compatability mode in Win7. To change the mode to XP do the following:
The compatibility mode has helped me play some of my classic games in the past. Post a reply with any issues or please rate this solution if you found it helpful. Thanks,
Edward
SOURCE: i have windows 7 and
hi anthonypauls
On ValuSoft 18 Wheels of Steel desktop shortcut right
click>properties>compatibility> check run this program in
compatibility mode for windows xp (service pack 3),
Toggle along with other windows version
Check to see if it works
Hope it helps,
Thx
Banaple
SOURCE: I have bought 18 wheels
Run it in compatibility modes try every one of them ones bound to let you install it.it worked for me.
