Grilling Logo
Posted on Feb 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Weak flame on webber q200 grill
"P" Burner for my webber grill seems to be clogged or the hose leading from the 10lb propane tank is either clogged it seems. my grill has a very weak flame even with the valve turned wide open
Anonymous
Level 3:
President:
  • Master 512 Answers
  • Posted on Feb 25, 2010
Anonymous
Master
Level 3:
President:
Answers
512
Questions
0
Helped
208130
Points
1697
Remove connection to tank, reconnect, open valve slowly, when you open valve to fast the tank valve has a shutdown in it, it thinks something is wrong and shuts valve down. Always open tank valve slowly when using.
Also your tank valve could be sticking causing this problem, to fix replace tank.
Poor flame after changing tank on gas grille
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Model Q200, Propane model Get no flame on the burner. Apparently, getting no gas. Something seems to be stopped up. What to do?
Whether you're using a 20 Lb Propane Grill Tank or a screw in gas canister, the solution to the problem is the same .
1. Be sure you have enough gas in the tank or canister to maintain proper ignition.
2, If the above checks out OK. Turn the LP tank valve OFF or if you're using a screw-on canister
turn the gas valve OFF.
3. Disconnect the hose from the tank or unscrew and remove the gas canister.
4. Wait 5 minutes and reconnect the hose to the tank or reattach the canister to the gas valve.
5. Open the gas valve VERY, VERY SLOWLY (Slow Motion, slow). Once the valve is full open, light
the burner & turn it to HIGH. Did the burner light and does the flame height look correct?
If so, you solved the problem. Remember to always open the tank valve Very, Very Slowly.
if the above didn't solve the problem, you will either need to replace the Hose/Regulator Assembly or the Gas Valve/ Canister Holder. The Hose/Regulator Assembly you can pickup from any home center or hardware store that sell grills & accessories for about $30.00. If it's the Gas Valve/Canister Holder, you will have to purchase that from Weber or from Factory Appliance Parts http://www.appliancefactoryparts.com/gasgrillparts/brands/weber/q200.html Part # WEB4195 ($29.99) The adapter hose is also available there if you want to make it a one stop shop for $32.99
I hope ths helped you and thanks for choosing FixYa. Happy Grilling!!
Seems like burners flames dont get big
Paula, you're propane tank may be almost empty or the OPD Valve in the tank has locked up your grill regulator. To test this theory, turn the propane tank valve OFF and disconnect the hose. Wait 5 minutes and reconnect the hose. Turn the tank valve ON VERY, VERY SLOWLY (slow motion, slow). Once it's completely open, light the burner farthest from the tank first and turn it to high. Does the flame height appear to be normal? If so, light the remaining burner(s) the same way. If all the flame heights are now normal, you solved the problem Just remember to alway trun the tank valve ON very very slowly. If that didn't solve the problem, you need to replace the grills regulator/hose assembly. You can purchase it at any home center or hardware store that sells gas grills and accessories. Just take your old one wih you for comparison purposes.
Hope this helped you to get back up and grilling!
Q200 weber grill getting gas flow but only at low and cannot regulate flame or raise temp for cooking
This sounds like a case of the OPD tank valve on the propane tank has locked up your regulator. In which case, turn the tank OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose. Now, turn the tank valve ON VERY, VERY SLOWLY (slow motion, slow). Once the valve is completely open, light the burner farthest from the tank first and turn it to the highest setting. If the flame appears to now be normal, light the remaining burners following the same procedure. If all burners have returned to normal height, you solved the problem. Always remember to turn the tank valve ON VERY, VERY SLOWLY.
If the above doesn't solve the problem, you may need to replace the regulator/hose assembly, which you can purchase from any home center or hardware store that sell gas grills and accessories. Take your old one with your for comparison purposes.
1helpful
I just purchased a brand new tank of propane and i still have the same problem that the propane burns out of all 4 burners but at a really low flame even on high. I can not get the grill to heat up...
Turn the tank off. Disconnect the grill hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the LP tank valve on VERY, VERY SLOWLY until it's fully open. Now, light each burner one at a time and turn it up to the highest setting. If that didn't solve the problem, repeat the previously listed steps.
If after the second attempt the burners still only maintain a low flame, you will need to replace the grill hose/regulator.
Hope this solved your problem and Happy Grilling!
1helpful
We have a spirit grill with 3 burners. I can light the grill, but burners 1 & 2 don't have a nice line of blue flame like burner 3. Burner 2 is especially bad with orange flames on the right and left...
Are you sure there's adequate gas in the tan? If so do the following:
Disconnect the LP tank from the grill hose. Wait 5 minutes and reconnect to the tank. Open the tank valve VERY,VERY SLOWLY, until it is full open. Light your burners individually and turn to highest flame setting, before lighting the next burner and so on.
If that solved your problem GREAT. Remember to turn the tank on that way in the future.
If it didn't you'll need to remove the burners and clean each one.
Hope this helped to get you back up and grilling again.
New webber will not start
Ok, let's tackle the obvious things first. New grill with new tank... so was the tank filled? Did they purge it before they filled it? Did you turn the tank valve on very slowly? Were all the grill knobs turned to off when you turned on the gas tank? Try closing the propane tank valve, disconnecting it and reconnecting it. Then very slowly turn it on and light one burner at a time at turn to low heat. Then light additional burners the same way and adjust flame as needed after all are lit. Hope this helps! Douglas
1helpful
2answers
Is not heating properly , the flame is not as strong as it used to be.
This is a common problem with grills purchased after 2001. There is a new safety feature inside the regulator called a 'surge protector'. If you open your propane bottle valve too quickly or if you try attaching a tank with the tank valve in the 'open' position, the propane wants to 'surge' into the grill.
When the propane surges into the regulator (located on the grill hose) the 'surge protector' (inside the regulator) kicks on. When this happens you will not be able to get your grill lit, and if you do, it will be a small blue flame and the grill will not heat up.
So what to do if you trip the surge protector and can't get your grill to light or heat up?
Shut the tank off and shut the valves on the grill off. Disconnect the tank from the grill hose. When you disconnect the tank from the hose you will hear the excess pressure of propane release. This is an indication that you have re-set the regulator's surge protector.
Now that you have deactivated or reset the surge protector, reconnect the tank. Make sure the valve on the tank and the valves on the grill are in the closed and in the off position. After you reconnect the tank to the hose, SLOWLY open the tank valve (making sure the valves on the grill are in the OFF position).
Since you have slowly opened the valve on the tank, the propane did not surge into the regulator and the surge protector did not activate.
Now open 1 valve on the grill and light it. You should get a nice flame. If your grill has more than one valve, open each following valve in sequential order to extend the flames to the other burners.
Thanks for reading and I hope this helps.
Ben Gaetani
Tanks 2 You Propane
propanetanks2you.com
[email protected]
1helpful
Weak Flames on Propane Grill
It is possible that your burners are clogged. Clean the burner ports with a paperclip (not a toothpick).
6helpful
2answers
Cannot get good flame on the burner of my baby weber grill. I've tried cleaning it checked hose, tank, regulator, seems to have good flow, but low flame only, even when set in high????????
I had this problem with a brand new grill so it wasn't grease in the hose. Due to the new propane regulators you have to turn the propane tank on for at least a minute before turning the grill to light. Let the tank sit in the light position for five seconds and then you light the grill. This will keep air from getting into the intake hose and will keep your gas flame roaring high.
I was only able to get the grill up to 250 degrees before I found this fix posted on the Weber site. It is listed as the number one solution in the FAQ section.
Top Weber Grilling Experts
Paul Carew
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Weber Grilling Expert? Answer questions, earn points and help others
