The "mode" button is there to change the function of the + & - buttons.
If you press the mode button several times you will cycle through the various setting features of the clock.
Look for the one that sets the time zone and use the + or - buttons to select your zone.
Some experimentation may be required!
Check the back of the clock. There are 4 time zones. Below the text thee is a small button going up / down. Eastern time is at the lowest level. Pacific time is the highest level. Try up and down and you will notice the dark side of the map on the front of the clock.
Also, you have to let the clock run around over and over before it settles to your required time zone.
