1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
I think you mean "VGA" not "AVG". You can use the VGA to S-Video adapter to connect the laptop to the projector however you may get better results using a VGA to A/V (component) adapter to feed video into the RCA video input connector.
If the projector has a lens cap, you have to help the projector to open it completely. Just use your finger and push the cap all ther way. On the projector I have this vis the case. there is a micro switch at the end og the lens cap opening mechanism.
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS3. 1st thing to check - is the cover properly/completely closed - this can stop the projector from working. Connect the power and set the projector to standby mode. Press these buttons on the remote control in this order, for less than 5 seconds each. Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS2
