Check the electric outlet to make sure the polarity isn't reversed, which can cause static. Also, check the outlets in the room to make sure they are all grounded which can also produce static. Also, certain cell phones operating a different frequencies can produce a static.
Reset the microprocessor. Instructions are in the manual.
Also try to get a different pair of speakers that you know work good and hook them up to the receiver to isolate if it is indeed the receiver or the speakers.
Denon has a service bulletin on repair of the HDMI board, which you might qualify for. Couldn't hurt to call the factory directly. Don't go to a local shop. Send it directly to the factory, because turnaround time is faster for some reason.
The manufacturer gives you a one year warranty, but sometimes credit card companies will extend the warranty for an additional year if you used a credit card to fund the purchase. Check with your policy.
Get a Onkyo or Pioneer receiver if more fidelity and less headaches are what you seek.
Don't know why Denon quality has gone to sh.t over the years.
It could be that there is a frayed speaker wire touching the back of the receiver and when playing at a low level the speakers do not require that much power, however when the level from the speakers increases more power is required and if there is a frayed speaker wire touching the back of the receiver there could be a short causing the receiver to shut down. A way to avoid the frayed wire is to use "Banana Connectors" that the speaker wires goes to and the connector will plug into the speaker posts. Please try the following to see where the issue is coming from. Have the receiver turned off, make sure all the speaker wires are labeled, and disconnect them from the speaker terminals. Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: www.onkyousa.com or www.integrahometheater.com.
okay, doesnt seem to be any of those it worked fine a few weeks ago. any other ideas im about ready to smash it
well i looked at the manual didnt see anything on microprocessors, speakers are the first thing i tried thank you i will get intouch with the factory, if you think of anything else let me know thanks again for the help
