Planar PE171 (Black) 17 in. Flat Panel LCD Monitor Logo
Posted on Feb 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a PE171 Planar monitor. goes black when turned on
I have a PE171 Planar monitor. When I turn it on the screen goes black.. after pushing the buttons off and on several times it stays on...fixable?
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Feb 25, 2010
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3368736
Points
33650
Your monitor has 3 years warranty, I would find out if you can get the replacement before opening up the case.
http://www.planaronline.com/product/?id=997-2723-00
  • johnn52 Sep 29, 2014
    that's a great fix! LOL LOL
2answers
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Planar monitor works but doesnt.
Try Another Monitor---If OK--Problem Is With Your Monitor---If Does The Same Thing--Problem With Computer Video.
Monitor turns goes black and comes back on every 10 secs planar PX2210MW
The Planar PX2210MW is notorious for bad electrolytic capacitors. Specifically capacitor C804 on the power supply board. . This is a 1000uF 25volt capacitor. That capacitor was usually made by Hermei and it was purple. Normally, the top of a capacitor will be flat. When it fails, it will be curved upward and there may be some brown material leaking out.
If the monitor still will not work after replacing C804, the problem could be Q805 or Q806. These are located on the under side of the board. They are small black surface mounted chips. There are 8 pins on these chips. I have seen both AO4620 and APM4548A part numbers used. These chips contain a pair of MOSFET transistors. One transistor is n-channel and the other is p-channel. Look for a short in one of the transistors. I have repaired several of these monitors. C804 is always bad. How ever, in three cases, Q805 or Q806 was also bad 12c1ec2c-5a6d-4352-af31-150a0a92514c.jpg c9a53aae-2999-45c7-ad78-44ba51ac5a6c.jpg 795d93fe-9678-46c2-820a-767bea9babb0.jpg
On Planar PL1700 monitor, screen stays black after power failure
this is a common problem with the capacitor, try opening your monitor and see if there is a capacitor swalow like gonna blow... the capacitor has a form like a AA battery... if changing the capacitor the problem persist maybe is a problem with the board and you need to search if the board have continous power....
Planar Monitor Wont stay on
Okay.... If you can. install your drive. It may work. If not then your Hardware in your monitor is screwed. Or maybe something else but not to my knowledge.
good luck!
2answers
Planar PE191M monitor display will not stay on
iv come across this before sometimes people can see that the monitor is actually working but the light has gone out id say bad capacitors that are breaking down. if you want to DIY it take it apart and find the light pcb usually built on the power supply pcb and look for bulging or swolen capacitors this happens alot in my opinion. if you can DIY it get the same caps or same value but better ones. I might be wrong but worth a look
PLANAR Flat screen goes blank and then wil not come back on, blinks a second then dies.
Hi...there
Sure, you can fixed by replaced the backlight inverter or repaired it.
Same problem
It may be the back plane lamps, and or the back plane power supply that is in a failing condition. If in your model they are changeable, they should be changed together.
You can verify this by turning on the monitor, feeding it with a known working source, and shine a flashlight in to the screen at an offset angle to your view. If you can see some image in the screen, then you know that the monitor itself is functioning, and the problem is back plane lumination.
Jerry G.
3answers
OSD Menu won't turn off
Known issue -- can get a replacement if still under warranty. The planar rma techs are really really nice.
Top Planar Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
