No need to buy a fan if u can uncover your laptop spin the fan through yr finger is it spin smothely or not & also check the fan jack inserted properly or not clean the fan with brush repack switch it on if problem persist contact me
My fan for the gateway M7315u has a different problem altogether. Under normal operations the Fan just suddenly spins uncontrollably and makes a high pitched noise. I have opened the casing and cleaned the whole fan and surroundings for dust and other foreign objects. It is clean. I unplug the fan from the circuitry every now and then for a brief moment and when I plug it back in it just jumps back up to 100 miles a minute. You got any ideas? Someone suggested the possibility of a bad bearing. If so I want to get the fan replaced or upgraded if at all possible.
SOURCE: computer wont boot
yep you said it loose connection, wiggle the power cord and and thing attached.
