I had the same problem. I tried to clean it, brush out crumbs,
gently "bleed" it and so on until I saw Quebol96's answer to the same problem: www.fixya.com/support/t3077478-leapster_will_not_recognize_pen_first
Quebol96's solution worked perfectly!
From Quebol96:
Answer
If your Leapster2 does not respond to the stylus pen, it needs to
be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted
2) Hold down the Hint (?) button while turning the unit on.
Continue to hold the Hint button down until the LEAPSTER menu appears.
3) When the LEAPSTER menu screen appears, press the A button
4) Touch each of the crosshairs that appear with the stylus
5) Restart unit
