Without the watch model it is hard to help you set the watch. Some Seiko watches use the watch stem which has two positions. Sometimes it is hard to identify the indentations so you may want to pull the stem all the way out then carefully push the stem to the first indentation. This will activate the alarm until it is pushed all the way in. When it is in the alarm on position, you can use the buttons to set the alarm time. However, I have 10 Seiko watches, and they are all unique to their functions, so it is best that you go to the link below and put the caliber code from the case back and look at the instructions.
http://www.seikowatches.com/support/ib/index.html
SOURCE: reset timer after battery change in seiko sna285
If the stop watch hands are not in the "0" (12 o clock) Position, follow the prodedure below to set them to the 12 o Clock position
1, Pull the crown to secound position
2, Press Button "A" for 2 seconds.
3, Press Button "B" to Adjust the minute Hand to "0" Position
4, Press Button "A" for 2 secounds then press Button "B" to adjust secound hand to "0" Position
5, Press crown into normal position
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
SOURCE: setting time & alarm on Sharp Chronograph wristwatch.
Instructions for Sharp Alarm Chrono (Digital)
Push "Mode" button until the mode is shown that you want to reset, do this even if the mode you want to reset is all ready showing.
Push "Reset", continue pushes until the desired Parameter (Minute, Hour, or Second) is flashing.
Use "Start" button to advance the digits to the desired setting.
Push "Mode" Button to finish.
SOURCE: seiko chronograph alarm
That was the answer but I can't rate it the normal way so I rated it this way. 4 stars!
SOURCE: Seiko Chronograph Sport 150 - Problem: After
Please folow this link:
http://www.seiko.co.uk/support/instructionbooklets
Enter your calibre code (its on the back of your watch, it will explain which numbers to you on the website), you'll then be able to download an instruction manual for your watch, this will detail how to adjust hands to their corect starting position :)
Testimonial: "PDF link states reseting the watch is the problem, and now that I have instructions, I should be able to reset the watch. Thanks"
SOURCE: Hello, I have a Seiko Chronograph Titanium 100M.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all SEIKO watch manuals. Rate me, please
