White Noise Sound
Your problem is somewhere between the tuner and video detector circuit.
The signal entering your TV carries: video,red color,and blue color as well as sychronizing pulses for color and horizontal and vertical deflection ( actually vertical sync. is derived from horizontal sync.) along with burst pulses to synchronize the color. After all these, the sound is an fm signal entwined with a pilot signal for stereo audio. WHAT a mess!
After the audio passes through all this, it is detected and sent to the audio processor.
If any frequency has drifted away from it's value then you loose the sound.
SO... your problem could be in any of the tuned circuits or in the audio processor IC (chip). Any component changing value could creat this problem. Most likely the audio processor IC. You'd need to have the set checked out by a tech to find your problem.
Stargazer
