My ironing station is spitting out dirty water
The dirty water coming out of your iron steam holes is caused by the accumulation of 'dirty' tap water: if you look inside an eletric kettle, you will see the same 'dirty' muddy brown mineral residue on the inside. In addition, if your iron is old, it can also be rust.
It is a pretty common problem that can be minimized by using distilled water.
You can get commercial steam iron cleaning fluid to clean the inside of your steam iron or you an simply use vinegar:
1) with a cold iron, fill the reservoir with straight vinegar
2) Place your iron on top of a metal kitchen rack above your kitchen sink, turn iron on and let it steam out all the vinegar: it should spit out the whitish mineral and muddy brown deposity.
3) Refill iron reservoir with clean water and repeat as of step 2.
4) Refill iron reservoir with clean water, wipe any dirty from the sole plate and this time on full steam, iron on clean layers of Kitchen paper to ensure that all dirt has been removed from the inside of the iron reservoir, if not, repeat from step 1 again.
In the future, try to use distilled or at least filtered water.
Hope it helps: let me know how you go!
