How many square feet of floor do I need if it's 9.3 feet one way and 11.7 feet the other way
Good morning Lisa!
There are likely two or three answers here.
Multiplying out directly, you get 9.3 x 11.7 = 108.81 sq feet.
But, the only floor covering that goes down like that is paint.
If you are putting down 12x12" tile, then you'll need to go 10 wide in the 9.3 foot direction (with cut tiles for the last .3 foot), and 12 long in the 11.7 direction, so you'll need 120 x one square foot tiles.
If it's tile of another dimension, divide the dimension into the 9.3 and into the 11.7, then round the answer up to the next whole number for each, and multiply together. 2x2 foot tiles would go 4->5 times for 9.3, and 5->6 times for 11.7, to give you 5x6=30 tiles x 4sq ft/tile = 120 sq feet.
If you're doing wooden flooring, you'll do a similar calculation based on the width of the wood laths, divided into one dimension and rounded up, times the linear feet needed in the other direction. If the boards are 4 inches wide, running parallel to the long wall, 4" goes into 9.3 feet 27 times, so round to 28. 28 x 4" = 9.333 feet You need 11.7 linear feet the other way. 11.7 x 9.333 = 109.2 sq feet. Though you won't likely be cutting 11.7 foot long pieces off of some piece as long as a full tree, so divide the board length into 11.7 and round up. If it comes in 3 foot sections, then 3 goes into 11.7 three times, round up to 4, so you'll have 28 widths x 1/3 foot per width x 12 feet length per strip = 112 sq feet.
Hoping this is helpful. good luck!
