Whirlpool 5' Jacuzzi  Tub Bathtub Cetra 532 H525-969 Logo
Posted on Feb 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool Jacuzzi with 10 jets one stopped working.
I have a whirlpool Jacuzzi Espree 536 ser# JBBJCQ mod# U640 with 10 jets one of the four back jets, top right has stopped working.
Anonymous
Level 2:
Champion:
  • Expert 207 Answers
  • Posted on Feb 24, 2010
Anonymous
Expert
Level 2:
Champion:
Answers
207
Questions
Helped
51218
Points
479
Either one of ur hoses has come off or is stopped up get to the sides and see if one has come off
2answers
I have a espree 536 whirlpool jacuzzi tub the on and off botton doesnt work what could be the problem
Check under skirt and see if gfci receptacle has tripped. If it has you should call electrician.
My air bubbles on my Espree Aero Flo modelDS75 are not working why
If the bubbles are not working on the tub it could be the check valve is stuck closed or the air blower is not working.
How to fix jacuzzi tub will not shut off bubbler
if the air blower will not shut off then it will either be the air switch in the blower or the control module that operates the blower will be bad.
Removal of air swicth model U640
http://www.harborfreight.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/i/m/image_21405.jpg
It sounds like the machine uses security-type fasteners, which require special screw bits. You may be able to remove the screws with one of these security bits, such as those sold by Harbor Freight.
I have a jacuzzi espree 536 model U640. The jets would not shut if with the switch. I unplugged the unit and now it will not turn on
When a jetted tub will not turn off it is usually because the air switch in the motor has quit functioning.
A new air switch for your pump costs around $20
US Parts Center
Oct 27, 2013 • Home
I have a Jacuzzi whirlpool bath model U640 Espree 536 and it wouldn't shut off. I cut the air line off at the pump and nbow it won't stay on for more than a few seconds. Any ideas?
I assume you hooked the hose back up to the air switch on the motor.
There will only be a couple of things to check.
Make sure you have a good connection with the air hose to the air switch on the motor. Sounds like maybe the air switch may be bad.
The Air Switch is a latching air switch so if is broken then it won't latch when the air button is pushed.
Rod
www.uspartscenter.com
I have the espree 536 jacuzzi tub. which heater is required for this unit. i ordered the s750000 but it is the wrong one
you will have to look to see where the fitting is to install this heater.
there are two styles of heaters they use (mostly)
In-line pressure heater that installs after the discharge of the pump but before any of the jets.
the in-line Vacuum heater installs before the front of the pump in the suction line.
I NEED DIAGRAM FOR JACUZZI MODEL U640 536 I HAVE THIS PROBLEM I DO NOT know WHERE to PUT THE HOSE from the ON|OFF SWITCH [email protected]
There is a small nipple on the back of the pump or the black box on top of the pump. This is where the tube attaches from the switch.
Jun 25, 2010 • Home
7helpful
2answers
I have a Jacuzzi Espree 6036 and switch will not shut off whirlp
Hello. yes you can replace the switch. All of the parts come with instructions. plus you can call the jacuzzi repair technician directly and have him/her talk you through the procedure at 866-905-2289. here is the owner manual in case you don't have one
http://www.guillens.com/jacuzzi/images/ESPREE.PDF
Top Whirlpool Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
