Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards
including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes PCMore beep codesPower up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you
still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display
which told you there was an error and offering you a
chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you
don't mind replacing it
