Sirius SUBX1 Universal Plug and Play Boom Box Boombox Logo
Posted on Feb 23, 2010
Need to disasseble my subx2 boombox to replace the attenna plug found only 3 screws under the handle and its not releasing
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Mar 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
11961
Points
14
After dissassembling my subxr2, I have come to the conclusion that the issue with my antenna not being detected is in the female contact of the antenna's plug, not with the connector in the box (as I expected to find). I have not yet verified this by trying a new antenna. Here is how to dissassemble the box in any case.
Very carefully, with a small very flat screwdriver, remove the front grille of the unit. There are 8 additional screws set in deep holes that need to be removed. Once done, the front panel will pop right off.
The inside of the case is a mess of wires. You do not need to disconnect them if you do not want to.
Pry the grill off the bottom of the box. Remove the 4 screws that hold in the speaker. This will allow you to move the speaker that is in the main body out of the way.
The antenna jack is _not_ a part of the circuit board. If you look into the box, you will see a rectangular cut-out in the edge of the circuit board. There is a wire with a silver connector that is held in place by 2 screws. Remove those screws and you are now holding the antenna jack.
  • Anonymous Apr 07, 2010
    Follow up: It was in fact the connector on the original antenna and not the boombox plug. Plugged in a replacement antenna and it instantly worked, while the old antenna still does not.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 04, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2654
Points
The antenna plug on my sirius boombox is broken . where can i buy the male plug.
2helpful
2answers
Remove interior door panel 2002 Chevy tracker
No you don't need any special tool . Find all screws on out side of door trim panel and the window handle , the mirror cover plate , then just pull on edge of the panel .
Gently pry the front side door trim panel (3) from the front side door by disengaging the plastic retainers which secure the panel.
Position the door trim panel (3) away from the door in order to gain access to the front side window switch electrical connector, if equipped.
Disconnect the window switch electrical connector, if equipped.
Remove the door trim panel (3) from the vehicle.
Remove the front side window switch from the door trim panel (3) by releasing the 4 plastic retaining tabs, as needed.
Use a cloth in order to pull off the snap ring which secures the front side door window regulator handle (1), if equipped.
Remove the window regulator handle (1), if equipped.
Remove the front side master window switch, if equipped. Refer to Power Accessory Switch Panel Replacement .
Remove the front side door inside handle (1). Refer to Front Side Door Inside Handle Replacement .
Remove the outside rearview mirror opening cover (2).
Remove the screw which secures the front side door pull handle (4).
Removal Procedure
Remove the screw which secures the front side door inside handle (1).
Slide the inside handle (1) forward in order to release the retaining tabs which secure the handle to the door.
Open the front side door inside handle rod retainer and remove the front side door inside handle rod from the inside handle (1).
Remove the inside handle (1) from the vehicle.
Check out youtube video showing how to do it !
How To Remove Install Front Door Panel Suzuki XL 7
How do i replace 2 3" springs on stratford recliner.
Get Recliner-Handles Sofa Spring Repair Kit for La-Z-Boy ...
? 1:37
www.youtube.com/watch?v=_hHUNVAQsk0
May 28, 2015 - Uploaded by Faith Rogers
Recliner-Handles Brand Replacement Sofa, Sectional, Couch, Love Seat, Recliner, ... This sofa seat spring ...
Replacement Recliner Release Handle For Stratford and ...
www.recliner-handles.com/replacement-recliner-release-handle-for-stratf...
This flapper handle will fit Stratford and Stratolounger recliners and others that ... 3 3/4 X 3 INCH INEXPENSIVE EASY WAY TO REPAIR YOUR RECLINING ...
The hood release handle under the dash is broken and I need to replace the complete hood release cable assembly
Long at the base screw next to the handle.
You need to make space on the handle end to pull the latch off.
1helpful
SUBX2
It will be very difficult to get.
2helpful
2answers
Where can i get a replacement antenna for my ge portable super radio? also, how about info on installation.bthanks,norm.
Radio shack has replacment attennas. There is a scew in the back of the radio below the attenna. Loosen it. the lower part of this and the attenna will come out. at the top of the base part is a screw where the attenna bends back and forth. remove this screw and take off the top of the attenna (the telescoping part of the attena) get a replacment attenna thiis length (of top part). The bottom of new attena will have a screw toward the base where it bends back and forth. Take this screw out and replace the new attenna base with the old attenna base (the new attenna base won't fit in the radio correctly) Now insert the fixed attenna back in t he super radio and tighten the screw on back of radio. Hope this helps.
Bissel 3593Handle Release Lever/Pedall replacement
You need to replace slider release not just the handle. Take off the screws holding the black plate under the removavle canister the you will be able to see the slide release.
How to Change Car Attenna on Honda Accord LXI
the antenna comes out from under the finder panel , in the trunk there is a carpeted insert, that needs to be removed in order to access the antenna motor, you can take it out from there. it is easier with the radio off. that way the antenna is in the down position.
Sony CFD-E95L disassembly
There are 11 screws that need to be removed: Bottom - 2 on both sides of the word "ATTENTION"; 2 on the outer edge at the three and nine o'clock positions; 3 under the handle; 2 in the CD player compartment; and 2 in the upper left and right corners of the cassette compartment.
Top Sirius Audio Players & Recorders Experts
John
John
ZJ Limited
ZJ Limited
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
