I am all out of black ink and im trying to print a paper in red but it wont print because there is no more black. why cant i print in color when i have color?
For reasons known only to Brother you are unable to print ANYTHING if you are out of any color of ink. If you are out of black and need to only print in color it WILL NOT work
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white
Even when printing in black and white, color ink is used for the following reasons:
Automatic cleaning of the print head.
To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
Therefore, although printing in black and white is performed, color ink is also consumed.
Color inks may be used to create black.
When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
Therefore, although printing in black and white is performed, color ink may be consumed.
In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Probably what happen is that you are printing black and white but you have your printer on color mode, try to set the printer to grayscale or black and white before print. The printer is tring to get the black and white by mixing all three color, that is the most comon way of make black, so, when one of the color is missing you see those red lines.
Also you will solve the problem replacing the color cartridge.
Your issue with the black ink only is because the print head my be dried up. Witch me that the ink cant flow to the "paper" fast enough. So by time to rollers eject the paper, the ink cant print on the paper. I had the same problem with my Kodak EasyShare 5300 All-In-One. So I contacted Kodak and they are sending me a new one. Try doing the same. Contact your manufacture and ask them..... :)
Now put out u color cartridge and take one tissue paper or toilet paper then put ink color head to paper(soft pressure).after that see u paper are inside show three color appear in paper????(red,yellow and blue).if all have means you cartridge ok if only same or no any coming out means u color ink problem need to replaced new unit.
if got all color out better u open u printer body and check are all cable u plug in back is correct or wrong position??.second u can try go to printer preferences go to find print out in color or in gray-color and change their setting to print out in color
The HP all-in-one product will print black copies using both the color and black cartridges to create composite black in Normal and Best modes. This is necessary to create the correct grayscale shades.
The color cartridge may be out of one color of ink. Perform the steps in the 'Colors are not correct' section above to verify that the ink cartridges are not low on ink.
Verify that the correct paper type is selected in the Paper Type setting.
Some photo paper has different chemical characteristics than Hewlett-Packard paper. The HP all-in-one is designed for use with HP Premium and Premium Plus Photo Paper. The photo paper, paper-type setting should be used with HP Photo Paper. For other paper brands, it may be necessary to use the plain paper or premium Inkjet paper, paper-type settings.
OR: The ink cartage you have may be defective if is a refilled or recharged cartage.
I have had the same frustrating problem.
I cntacted the Kodak live web chat help line and after removing the print head,switching the machine off for 1 min and reconnecting.Clean heads and recalibrate.
.....Still the same.
They then told me the print head was faulty and to contact Kodak for free repalcement.
Hi Greenhorn,
Your info is slightly conflicting - I think.
As I remember the C60 has just 2 LED's:
1 - Green for Power
2 - Red for Error
The third button - Cartridge exchange - has no LED
Now it is a while since I looked at a C60 and my brain leaks like a sieve, but that's the way I remember it and feel free to correct me if I'm wrong.
The error codes I remember are:
Printer status - Indicators - Priority
Power - Error
Power ON condition On -
Ink sequence Blink -
Ink Cartridge change mode Blink -
Data processing Blink -
Paper Out *1 - On
Paper jam condition *1 - On
Ink end (Black) *1 - On -> Blink
Ink level low (Black) - Blink-> Blink
Ink end (Color) *1 - On -> Blink2
Ink level low (Color) - Blink-> Blink2
Ink end (Black and Color) - On -> On
No Ink Cartridge (Black or Color) *1 - On
Maintenance request (Ink Overflow Countererror) *1 Alt Blink Alt Blink
Fatal error *1 Off On
Special setting Blink2 Blink2
