Dell Latitude D610 Notebook Logo
Posted on Feb 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot do a Print Screen with my Dell Latitude d610. I have tried all combinations of Ctrl+Prnt scrn and Fn+Prnt scrn. Any idea's?
  • natasha
    natasha Nov 05, 2014
    i been using www.gyazo.com on all my computers and am also having major issues with my dell lattitude d610 right now i posted a question about it i hope someone can help me
Anonymous
Level 3:
  • Master 742 Answers
  • Posted on Feb 24, 2010
Anonymous
Master
Level 3:
Answers
742
Questions
0
Helped
193887
Points
2315
Based on your keyboard layout, you don't need a key combination to capture your screen. Just press the "Print Scrn" button and your screen image will be copied to your clipboard. Now if you have pressed the "Print Scrn" key, go to MS Paint or any other image processing programs and "paste" it there.
Notice that your "Print Scrn" key is printed on top of the keyboard key and in white color. That means that it is the default key when pressed so there is no need to combine with Fn or shift. But if it is printed in blue or orange (your Fn key should be in blue or orange also) that is the time you need a key combination.
3answers
What keys do I use for print screen
What are the keys to print screen?
Print screen (often abbreviated Print Scrn, Prnt Scrn, Prt Scrn, Prt Scn, Prt Scr, Prt Sc or Pr Sc) is a key present on most PC keyboards. It is typically situated in the same section as the break key and scroll lock key.
Print screen - Wikipedia
https://en.wikipedia.org/wiki/Print_screen Search for: What are the keys to print screen?Copy only the image of the active window
  • Click the window that you want to copy.
  • Press ALT+PRINT SCREEN. Important: The text you see on your keyboard might be PrtSc, PrtScn, or PrntScrn. ...
  • Paste (CTRL+V) the image into a Microsoft Office program or other application.
Copy the window or screen contents - Office Support
https://support.office.com/.../Copy-the-window-or-screen-contents-98c41969-51e5-45e... What keys do use for print screen Google Search
Screen print click
try just pressing print screen if that does not work it may just require holding the Fn key and then tapping the print screen key. if non of these options work there is always other programs that you can download a program like Fraps for example that you can bind a new print screen key like F8
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tyler_d7f5052aae55714c
How do i do a "print screen" with my samsung laptop, can't seem to find the key on the keypad
look toward top righthand side of keyboard for a key saying, (prnt scrn) or similar, if the writing on the key is coloured there may be a key labeled FN next to the control key bottom lefthand corner of keyboard which you have to press together with prnt scrn. hope this helps.
1helpful
How do you "print screen"
Its either going to be Prnt Sc or press the Fn key and then the Prnt Sc
2helpful
Windows xp dell latitude e6400 print screen command? tried fn+alt+ (f11) prt scrn and fn+(f11) prt scrn neither worked looking foreward to hear from you
What the Print Screen option does is copies the screen to the clipboard. You will need to use a program such as Word and past the content to the open page.
By hitting the Print Screen button by itself will show the image of the desktop.
The Alt + Print Screen combination will give you a pic of the active window
You can also try this...
If your Print Screen is labeled in blue & your Function key is also blue then you have to hold Fn key while using Print Scrn , "Fn"+"Print Scrn" or "Fn"+"Alt+Print Scrn"
let me know if you have any other questions..
Thanks!
Lori
pls leave feedback/rating
27helpful
4answers
How do you do Print Screen with a Dell E6400 laptop? The alt-print screen combination of keys doesn't copy to the clipboard. Are there other keys for this?
Press Alt+Fn+(Prnt Scrn) to take screenshot of the active application. To take the snapshot of the whole screen, press Fn+(Prnt Scrn).
Please give good ratings if this answer helped you.
Thanks
1helpful
I don't know how to turn on wierless
> Vendor/Model-----------Type----------Location
> Dell D600 & D610-----KeyBoard-----Fn+F2
> HP nc4000 & nc4010-----Button-----Above Keyboard
> HP nc4220-----Button-----Left Side of Laptop Near USB Port
> HP nc6000 & nc6220-----Button-----Above Keyboard
> HP nx9010-----Button-----Front side of laptop
> HP Omnibook 6200-----Button-----Left side of laptop
> IBM T43-----Keyboard combination-----Fn + F5-----Click "Turn On"
> IBM X32-----Keyboard combination-----Fn + F5-----Click "Turn On"
> Toshiba M1 & M2-----Switch-----Left side of laptop-----Towards
> front
> Toshiba R100-----Switch-----Right side of laptop
> Toshiba TE2000-----Switch-----Left side of laptop-----By Vol ctrl
> Toshiba Tecra 2100-----Switch-----Left side of laptop-----By Vol ctrl
Or you can do that from device manager.
My Dell D610 laptop monitor has went completely white.
I don't have a Dell D610 with me, there should be a VGA/SVGA port on the back. If not, there's a DVI port.
If the video has not gone bad, you should be able to. Connect the monitor to the back vga/svga port or DVI port.
The are several controls to activate the monitor for Dell computers.
CTRL ALT <
CTRL ALT F10
FN F8 (CRT/LCD)
FN D
FN F12
Good Luck.
1helpful
3answers
Prt scrn button does not work on Gateway KB-0532 keyboard
It doesn't work on my laptop. It works if you hold down the FN key whilst pressing the prt scrn button, if you cannot find the FN key, on my laptop it is next to the CTRL button on the bottom left. Hope I've solved your problem!
1helpful
Print Screen Function
On the top row, on the right hand side, second from the left, there should be a Print Screen key (Print Screen / SysRq). Just press that key once - it should give you a PrintScreen.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
