Question about Samsung SyncMaster 910T 19" LCD Monitor
Hooked Samsung SyncMaster 931BF monitor to laptop and the letters on the screen are choppy. I can play with the settings on the monitor but can't get the letters to line up straight.
    Scholar:
  • 45 Answers
This looks like a driver/resolution problem. Which laptop are you using? New laptops shouldn't give you any hassles, but older models don't always have the graphics cards to support all monitor sizes.
Make sure your monitor driver is installed on the laptop and that you have the latest graphics drivers installed for your laptop.
You can download the screen driver here: http://driverzone.com/device.php?id=55741
Then check that the resolution for your monitor is set correctly on your laptop under display properties. The native resolution for the screen is 1280x1024.
Hope this helps,
-LL
Posted on Feb 23, 2010
SOURCE:
Samsung syncmaster 913v gives message ' not optimum mode"
The 913V has a native resolution of 1280x1024. If you use a higher resolution than that, you'll get slightly blurry text. If you use a lower resolution, then images will be slightly choppy around the edges.
To get rid of the message, set your resolution to 1280x1024.
In Windows XP, you do this by right-clicking on the background (desktop) and selecting "Properties" to bring up the display properties.
Select the tab marked "Settings" and look for a "Screen Resolution" slider. Move that slider to the right until it displays "1280x1024" and hit "OK"
Oct 03, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
How to open case/shell of Samsung SynMaster 931BF???
You remove all the screws, stand, then useing the thin flat blade screw driver to crack open the case, starting at the bottom edge and work your way around, it is hard to tell you in words. Try Youtube also.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 15, 2010 | Samsung SyncMaster 931BF LCD Monitor
I have a Samsung SyncMaster 931BF. I love the screen, but for quite awhile, the screen has been having a hard time coming on and staying on. I'll have to cycle the power multiple times to get the screen...
Remove its stand
Unscrew all the screws in the back.
It doesnt just lift off I guess you could say, there are many clamps around the edge that need to be "popped" by sliding anything thin enough to get between the front and back of the case to pop them.
I popped mine open the other night. The clamps appear to be hard to break, at least in my circumstance. None of them broke with a fair amount of pressure from pulling being applied.
Also, mine had your exact same issue until one day it no longer turned on completely. It just flashed the screen once and showed a flashing power light around the button. Replacing 3 capacitors that were just barely bulging on the top fixed the issue.
I can't get my Samsung SyncMaster 931BF to come of of sleep mode?
I already post solution for this problem, click here to see the solution.
Dec 21, 2009 | Samsung SyncMaster 931BF LCD Monitor
Syncmaster paower button blinking and no display
CHECK THE REFRESH RATE ON TH OLD COMPUTER MONITOR AND MOVE IT TO A HIGHER REFRASH RATE IN THE CONTROL PANAL, MONITOR, PROPERTIES, ADVANCE SETTINGS
ROD
Feb 10, 2009 | Soyo DYLM1986 Monitor
A 'Fatal Exception Error' to give it its' correct name happens when software and hardware clash and don't know what to do.
Delete the SynchMaster from Hardware in Control Panel - System. Then Reboot, now go to the maker of the Video Card in your computer and Download the latest Drivers and Software. This is where your settings come from, not the monitor. Once loaded, reboot again. Now play with your settings in Control Panel - Display.
Jan 09, 2018 | Computers & Internet
Samsung SyncMaster 910T 19" LCD Monitor Logo
219 people viewed this question
Top Samsung Computers & Internet Experts
asber
RONALD CARTER JR
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
