Bosch 24 in. SGS47E02 Exxcel Free-standing Dishwasher Logo
Posted on Feb 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Bosh Diswasher model SHE44C02UC gets stuck on rinse at the end of any cycle with 1 min showing on the timer and wont clear? The water does not drain. I need Help
Anonymous
Level 2:
  • Expert 457 Answers
  • Posted on Feb 25, 2010
Anonymous
Expert
Level 2:
Answers
457
Questions
Helped
126527
Points
799
Module or drain pump need ed call 1-888-nyc-1055 they are pretty good with any bosch appliances.
My 15 yr old Bosch d/w starts at 13 min & runs to 1, doesn't gets to CL. No water in or drain out.
IF IT ENDS UP WITH WATER SHOWING AT THE END OF EVERY WASH THEN THE DRAIN PUMP IS JAMMED OR FAILED THE DISHWASHER PROG WILL JUST KEEP LOOPING BACK TRYING TO DRAIN THE WATER.
My eurolux dw2112p/1 gets stuck halfway in rince cycle
replace the timer: a tiny gear that is driven by the timer mpotor has broken teeth at that time point
2answers
How can I clean my cloudy glasses? How can I stop my glasses getting cloudy?My Bosh model is "Bosh Classixx"
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
16helpful
2answers
Dishwasher stuck in cycle
Hi
I have a similar problem, did you find the cause of the problem?
Geoff
Jan 13, 2010 • Dishwashers
LG tromm washer stuck in rinse cycle
  • I had the same issue of being stuck in rinse and timer stuck at 20 min. Mine was a water flow problem, at the back of the washer where you hook up the water there is a small in line screen to stop debris from water supply. I removed them, they were clogged, cleaned them up, works great!!!
Bosh dishwasher not working
It is possible. It is also possible that the water temp is too low and it is taking that time to heat the water. If it seems to be making a humming sound the entire time, like it is draining, see my guide here to clear the clog. I too thought mine was not filling at first, but these have a good number of drainage issues that are misdiagnosed as control board and fill valve problems.
2answers
My Kenmore diswasher gets stuck between the quick rinse and drying cycle
I am having the same issue as described above. I think it is either the timer, thermostat (temp assure), or thermostat (temp boost) that needs replacing. The dial gets stucks in both the wash temp boost cycle and rinse temp boost cycle. However, I don't have a picture of the temp assure or boost part. Does anyone know how to fix this? Thanks. -Bill
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
