Whirlpool LER6636PW Electric Dryer Logo
Posted on Feb 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model no. is ler6634DZO Just quit and will not do
Model no. is ler6634DZO Just quit and will not do anything. ckd wires and brker box
Anonymous
Level 3:
Genius:
  • Master 1,122 Answers
  • Posted on Feb 26, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1122
Questions
5
Helped
316650
Points
2771
First check the door switch,then check the main fuse behind the back panel to your left-mike
Quit running & will not restart. cked the brker, ok.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 04, 2011 • Dryers
Ac unit pop breaker
A breaker trips because it is overheating. This is caused by the brker being to small, the wiring is to small or the line overloaded. Your unit should be on a dedicated line and the breaker sized to the unit. Also breakers do go bad over time from being overheated and need to be replaced. If the breaker tips instantly it means the AC unit or wire has a direct short. If it runs for a while and then trips the bkr it is in the bkr or wiring.
Ge wall oven will not heat up on bake,boil or clean cycle
GE JKP86BF3BB COMBO MICRO/ELECT OVEN
NO HEAT ON BROIL OR BAKE ELEMENTS
CKD WIRING FROM PANEL OK
CKD TERMINALS AT ELEMENT HAVE 120V ON EACH ELMT
FAN COMES ON
THE ON INDICATOR SHOWS WHEN TMP &START PUSHED
MICROWAVE WORKS FINE
I ORDERED A NEW BAKE ELEMENT TO TRY-NOT HERE YET
STUMPED
KENMORE ELITE DISHWATER panel went blank but there
Check the continuity of the thermal fuse. It's clipped onto the electronic control inside the console.
Let me know if you need more help.
Whirlpool gas model LGC8858EQ1 dryer works fine except the timer does not move.
ckd for wire from thermostat on rear of blower or high limit might be easier to look at wiring diagram wire is usually orange they have been known to come off voltage is feed to timer motor during auto setting from a thermostat
Jul 30, 2008 • Dryers
Hotpoint wf541
ckd to be sure pump is operating in drain/spin feel pump housing for vibrationn from pump spining if pump not runing or huming ckd voltage to pump with wires removed.. voltage 110? pump probably bad ck for loose impeller they have been known to come loose from motor shaft..no voltage? ckd wiring at control bd last resort bad control bd..good luck
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
