Take a volt meter and check the contacts the phone sits on in the base station, there should be around 5 volts DC there, if there is I would replace the batteries in the phone, if there is no voltage at the charging contacts in the base then the base station is defective, another quick way to determine the cause of the problem is take the phone out of the base station and put it into one of the other phones chargers, then if the phone does charge up the base station charger is defective, u will need to replace the phone or not use the base station for charging. these are not repaired except under factory warranty.
Chornic Quick Charge 2 0 2port QC2 0 4port USB Charger 5V 9V 12V 60W USB...
Hello :
Technically, It would be an old battery issue, or the charger itself, try using another charger, if the problem still occurs, maybe it's the battery or your's phone's charger jack had a hardware issue.
I hope that will help .
rate if useful please !
i did replace old battery from fully charged battery from another phone (have 3 handsets).this base phone then lost its fully charged status.what does that mean ?
when i changed battery of the base phone in question from another handset which was fully charged,the base phone shows lost battery charge.what does that mean ?
