LG LFC23760ST Side by Side Bottom Freezer French Door Refrigerator Logo
Posted on Feb 23, 2010
Burned our fuse in circuit board
I have a burned out fuse in circuit board at the rear of my LG Model 23760 st fridge. The fuse is "Fuse 1, 125V 15A" and it is soldered into the board.
Ideas?
  • chuc820 Mar 12, 2010
    have the same problem, fuse blown on board
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
875
Points
It is a 250V 15 amp. clip the fuse off the wire, close, and solider in a new one. Terrible design. LG should have to replace free or be sued !
Anonymous
Level 1:
New Friend:
  • Posted on Apr 22, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
875
Points
Watch the video,it's most likely the larger glass fuse mounted on the mother board. Easy fix
2answers
2006 chevy trail blazer cruise contol does not work. Cant find a fuse under hood or under back seat. Help
Your owners manual should show you where the fuses are located. If you don't have an owners manual, you can go to
my.gm.com, type in your year--make--model and hopefully read your owners manual for free.
Do the brake lamps work ok?
I found these fuses, not only check fuses, check for voltage on fuse circuit, use a test light. Some fuses are hot all the time, some go hot with the key on.
Any codes for the cruise system?
2000 Ford mustang 3.8 cranks won't start diagnostic gives code b1353
B1353 Ignition Key-In Circuit Open GEM Go to Pinpoint Test B .
PINPOINT TEST B: THE KEY-IN-IGNITION CHIME DOES NOT OPERATE CORRECTLY
Do you know what the GEM - genaric electronic control is ?
You need a scan tool to check ignition switch position .Don't know if this would cause a no start . Have you check for ignition spark and fuel pressure ? Are there anyother problems with power door locks or windows or lighting ? Thing's the GEM controls ?
CONDITIONS DETAILS/RESULTS/ACTIONS B1 CHECK IGNITION STATES
NGS
Monitor the GEM PIDS IGN_KEY, IGN_A, IGN_S, and IGN_R while cycling the ignition switch through the OFF, ACC, RUN, START and key out positions.
  • Do the PID values agree with the ignition switch states?
Yes GO to B2 .
No GO to B4 . B2 CHECK GEM INTERNAL TONE OPERATION Trigger the GEM Active Command CHIME ON and OFF.
  • Does the chime operate correctly?
Yes GO to B3 .
No INSTALL a new GEM. For additional information, REFER to Section 419-10 . REPEAT the self test. CLEAR the DTCs. B3 CHECK GEM INPUT FROM DOOR AJAR CIRCUIT Monitor the GEM PID D_DR_SW, while opening and closing the driver door.
  • Do the GEM PID D_DR_SW values indicate CLOSED and AJAR correctly?
Yes INSTALL a new GEM. For additional information, REFER to Section 419-10 . REPEAT the self test. CLEAR the DTCs.
No GO to Pinpoint Test D . B4 CHECK GEM INPUT VOLTAGE FROM IGNITION SWITCH AT CJB FUSE 28 (15A)
CJB Fuse 28 (15A)
Measure the voltage between CJB Fuse 28 (15A), Pin 1, harness side and ground while cycling the ignition switch through all positions.
  • Is the voltage greater than 10 volts in the RUN and START positions only?
Yes GO to B5 .
No REPAIR the CJB. REPEAT the self test. CLEAR the DTCs. B5 CHECK GEM INPUT VOLTAGE FROM IGNITION SWITCH AT CJB FUSE 32 (15A)
CJB Fuse 32 (15A)
Measure the voltage between CJB Fuse 32 (15A), Pin 1, harness side and ground while cycling the ignition switch through all positions.
  • Is the voltage greater than 10 volts in the RUN and ACC positions only?
Yes GO to B6 .
No REPAIR the CJB. REPEAT the self test. CLEAR the DTCs. B6 CHECK GEM VOLTAGE INPUT CIRCUITS FOR OPEN - IGNITION SWITCH CIRCUIT 911 (WH/LG)
CJB Fuse 28 (15A)
GEM C352
Insert ignition key. Measure the resistance between GEM C352 Pin 8, Circuit 911 (WH/LG), harness side and CJB Fuse 28 (15A) Pin 2, Circuit 911 (WH/LG), harness side.
  • Is the resistance less than 5 ohms?
Yes GO to B7 .
No REPAIR Circuit 911 (WH/LG). REPEAT the self test. CLEAR the DTCs. B7 CHECK GEM VOLTAGE INPUT CIRCUITS FOR OPEN - IGNITION SWITCH CIRCUIT 1002 (BK/PK) Measure the resistance between GEM C352 Pin 22, Circuit 1002 (BK/PK), harness side and CJB Fuse 32 (15A), Pin 2, Circuit 1002 (BK/PK), harness side.
Yes GO to B8 .
No REPAIR Circuit 1002 (BK/PK). REPEAT the self test. CLEAR the DTCs. B8 CHECK GEM INPUT CIRCUIT FOR OPEN - KEY-IN-IGNITION SWITCH CIRCUIT 158 (BK/PK) Measure the resistance between GEM C352 Pin 9, Circuit 158 (BK/PK), harness side and ground.
Yes GO to B9 .
No REPAIR Circuit 158 (BK/PK) and key-in-ignition switch for failure. For additional information, REFER to Switch-Key-In-Ignition Warning . REPEAT the self test. CLEAR the DTCs. B9 CHECK GEM VOLTAGE INPUT CIRCUITS FOR SHORT TO POWER - IGNITION SWITCH CIRCUITS 911 (WH/LG), AND 1002 (BK/PK)
CJB Fuse 28 (15A)
CJB Fuse 32 (15A)
GEM C352
Remove ignition key. Measure the voltage between GEM C352 Pin 8, Circuit 911 (WH/LG), harness side and ground, and between GEM C352 Pin 22, Circuit 1002 (BK/PK), harness side and ground.
  • Are voltages greater than 10 volts?
Yes REPAIR the circuit in question. REPEAT the self test. CLEAR the DTCs.
No GO to B10 . B10 CHECK GEM INPUT CIRCUIT FOR SHORT TO GROUND -- KEY-IN-IGNITION SWITCH CIRCUIT 158 (BK/PK)
GEM C352
Remove ignition key. Measure the resistance between GEM C352 Pin 9, Circuit 158 (BK/PK), harness side and ground.
  • Is the resistance greater than 10,000 ohms?
No REPAIR Circuit 158 (BK/PK). REPEAT the self test. CLEAR the
Where is the rear window defrost fuse located and what color is it for a 2006 Ford Taurus?
A combination fuse and circuit breaker panel (called the fuse junction panel) and is under the steering column. Fuse Loc. Number Fuse Amp Rating Fuse Color Circuit Protected 1 - - Not Used 2 5A Tan Instrument Illumination 3 10A Red Left Low Beam Headlamp 4 10A Red Right Low Beam Headlamp 5 5A Tan Brake/Shift Interlock Rear Window Defrost 6 15A Lt Blue Back-Up Lamps/Air Conditioning, Speed Control, TR Sensor 7 10A Red Starter Relay Power, TR Sensor 8 5A Tan Radio Mute, Power Antenna, GEM Module 9 10A Red Anti-Lock Brake System, Central Temperature Monitor 10 20A Yellow Electronic Engine Control (EEC) Relay, Ignition Coil, PATS, Radio 11 5A Tan Air Bags, Alternator Indicator Lamp 12 5A Tan Gauges, Warning Lamps, Transmission Control Switch, GEM Module, Integrated Control Panel Autolamps 13 5A Tan Air Bags, Blower Motor, Electronic Automatic Temperature Control 14 5A Tan Light-Out Module 15 10A Red Multi-Function Switch (Turn Signals) 16 - - Not Used 17 30A Lt Green Front Windshield Wipers/Washers 18 5A Tan Headlamp Switch Illumination 19 15A Lt Blue Rear Window Wiper/Washer 20 5A Tan Radio Memory, Phone, Remote Anti-Theft Personality (RAP) Module, Integrated Control Panel (ICP) 21 20A Yellow Cigar Lighter 22 5A Tan Power Rearview Mirrors, Antenna, Decklid Lamps, Autolamp 23 5A Tan Generic Electronic Module (GEM) Power, Remote Anti-Theft Personality (RAP) Module, Passive Anti-Theft System (PATS) Module 24 5A Tan Integrated Control Panel, Radio, Speedometer 25 10A Red Diagnostics (Data Link Connector) (DLC) 26 15A Lt Blue Decklid Release 27 10A Red Battery Saver System 28 15A Lt Blue Stoplamps, Speed Control 29 15A Lt Blue Multi-Function Switch (Hazard Lamps) 30 15A Lt Blue Highbeam Headlamps, Daytime Running Lamps (DRL), Instrument Cluster 31 5A Tan Tail Lamps 32 5A Tan Heated O/S Rear View Mirrors, Integrated Control Panel (ICP) 33 5A Tan Power Window and Lock Switch Illumination 34 - - Battery Saver Relay 35 - - Driver Unlock Relay 36 - - Rear Defrost Relay 37 - - Interior Lamp Relay 38 - - Driver Power Window Relay (One Touch Down) 39 - - Accessory Delay Relay Since rear defrost is a relay, not a fuse, you're looking for a big black square that plugs into the board with three prongs. If it rattles when you shake it, it's probably bad.
1helpful
Where can i buy a circuit board for my lg refrigerator model lfc23760st
No need to buy a new main control board !
The problem is mainly from the fuse that soldered in the main control board, go to buy a "125V 15A or 250V 15A" fuse ($5.00 a pack of 5 pcs), cut the burnt fuse from the board, re-soldered the new fuse into the board, the refrigerator work again. you save $80 for the labour cost of the technician and $180 for the cost of a new main board.
2answers
Refrigerator does not appear to be getting power, no lights, don't here motor running
If you have no lights or hear the motor running, I would check the house circuit breaker first and measure the voltage at the outlet. If that is within specs then the one thing that could cause your problem in the refrigerator is the power control board P/N: 6871JB2047A
My LG fridge model LFC 23760 ST is 1 yr old and has started noises when compressor kicks in. The whirring of the fan has gotten quite loud. Any ideas?
It could be that the cooling area is being restricted by something. Remove the front panel and take a look to make sure everything looks ok. You should have a warranty and I would sure use that before you have more problems...
15helpful
3answers
The fuse in my LG refrigerator burned out and i have had the hardest time tracking down a new fuse. The fuse is soldered to the circuit board and rather than pay $180 for a new circuit board with the...
Radio Shak had it. I just did the same thing with mine and figured id try and give it a go myself. Turned out, $20 at Radioshak for a solder gun, fuse holder, new fuse and an hour of my time was worth it.
The difference between a "Fast acting" and "Slow burn" (also known as Time-Delay fuse) is one is for a resistive load, and the other an inductive load. Resistive loads are like lights and circuit boards, where the amperage is relatively constant. Inductive loads (time-delay) are motors, things that require a large in-rush current to get moving like the compressor on your fridge. Hope this helps.
2helpful
I HAVE A 250V/9A FUSE TOWARDS THE BOTTOM OF THE BOARD THAT HAS BURNED OUT..I CAME HOME FROM WORK AND THE FRIDGE WASN'T WORKING. OPENED UP THE CIRCUIT BOARD PANEL AND THERE IT WAS.. CAN THE FUSE BE REPLACED...
Just replace the fuse, I just did it today (3/6/10). Unf. Radio shack only had an 8A slow-burn fuse so I used that for now but the fridge is working. I nuked the leads on the fuse so I soldered on some of the lead of a thermal fuse that I also got at Radio Shack (I just used the leads and tossed the fuse). I also put the fuse inside of a harness in case it needs to be replaced again, no soldering. Good luck!
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
