Well Get Your Manual Book on the Page Setup Program Utility and Follow the instrution... Under Your Dash You Got what they Call The Terminal Box Connection For Computer Analyzer But off corse To do So .. You must bring your Car on The BMW Deeler To
Activate The Rom Memory Utility.. To Re-program your Light sensor What you call Welcome Lights On your risk Pin 2.8.13. must be short respectively with a diode 2 and 8 13 for ground. on your ignition If you miss it will just cost you S750 dollards for new computer Dash... So dont do it.. Try to re-program your Key Tranceiver some time they work Good luck
Since you have a M7310, you have either an MICS or a CICS.
Yes
it is possible, but you need to get into system prorgamming. If you are
not familiar with system programming, then you need an overlay for
programming. If you dont have/know either.....you should call someone,
as it is too hard to explain over a forum.
I have a Brother MFC 8860DN Network Fax machine and I need to program some phone numbers on it for automatic fax. I don't have the book to follow the steps to program it.
The DVD player at the back as the diff o/t for the Prgressive scan.
Plug the cables to that nd the click on setup, where you can hardly see.. move to the 2nd option and select scan
