How can I get a Jobmate 3 gallon air compressor parts diagram with parts numbers; Jobmate insists on the correct part number when ordering parts.
Good luck on this one. I own 2 jobmate compressors, one I bought and used very little before it blew apart and another a freind gave me to use for parts. Guess what the same part failed on both and I know of at ;east three more that also failed the same way.
I gave up trying to deal with Canadian Tire and Jobemate and junked them, as though they weren't junk to begin witn. You get what you pay for. I have a new Hausefield compressor and it is fantastic.
Hey tony you got a headache there is a Pn# 1-877-888-3872 to order parts direct From sunrise or known job mate i talked to Canadian tire about this product they dumped 3 years ago because the compressor heads were not verey reliable to many returns or repair problems Not worth fixing
Is that "inlet tap" the cylinder head with the discharge reed valve?
I fixed the Jobmate compressor problem. It was the broken inlet tap ( part # 3310250 ) $3.00 plus S&H...therefore I ordered piston ring ( part # 3490150 ) as well. Not a complicated repair...handyman sense. Worth to repair and not advise to use continuously because the cylinder head is very hot even one time use. Global Marketing, same phone #, in Markham, Ont carry the parts, can pick up with pick up fee.
Was that "inlet tap" the discharge reed valve that's part of the cylinder head?
The " inlet tap " was part of the cylinder head...you need to take out the orange color " O " ring in order to change the " inlet tap ". I heard the broken steel plate inside the cylinder head when shaked it, then discover the problem...too bad no photo could be posted here.
I just ordered the inlet valve and replaced it. Compressor works perfect. Part is 2 dollars 10 dollar shipping. I ordered two extra just in case. Easy fix.
Hey guys, who did your order this part from ? CDN Tire ? or other co ?
Part is 2 plus shipping and handling 10 dollars. Fixed problem. Thanks
Another picture. Inlet valve
Like I said easy fix. If you are going to order the inlet tap mY be a good idea to order a couple. Their only 2 dollar and u don't need to worry about shipping if it happens again
The valve cover is part #3310250 and the inlet tap is part #3310250-01. The manual has a misprint and shows both parts under the same number. I just ordered 3 and received just the valve cover and discovered the mistake.
