Tip & How-To about Televison & Video
The ARCHOS 7 offers customer uncompromised access to the Internet, TV and media content… With its stunning 7 inches amazingly high-resolution screen, 800x480 pixels, and huge disk capacity, it is the best travel company and portable audio/video player you can imagine, which will definitely accompany your travels and holidays in a comfortable and convenient way.
To enjoy videos on ARCHOS 7, you should make sure what file formats are compatible with it, following is the detailed information:
Video playback:
MPEG-4 (ASP@L5 AVI, up to DVD resolution)
WMV (MP@ML, up to DVD resolution) including WMV protected files
M-JPEG (Motion JPEG Video) in QVGA resolution
With optional plug-in (downloadable from your tablet on www.ARCHOS.com):
HD support: MPEG-4 (ASP 720p) & WMV HD (MP 720p)
H.264 up to DVD resolution with AAC
MPEG-2 MP@ML up to 10 Mbps (up to DVD resolution) and AC3 stereo sound (5.1)
Audio playback:
Stereo MP3 decoding @ 30-320 Kbits/s CBR & VBR, WMA, Protected WMA, WMA pro 5.1, WAV (PCM/ADPCM)
AC3 stereo audio and 5.1 sound files (via SPDIF output of DVR Station)
Flac and OGG Vorbis audio files
With optional software plug-ins (downloadable from your tablet on www.ARCHOS.com):
AAC, AAC+ stereo audio files
Obviously, the ARCHOS 7 supported file formats are limited, if you want to watch you various video files and unprotected DVDs on it successfully, format conversion is necessary. By now, Pavtube Video Converter would be a good assistant for you. It is able to help you convert videos from DVs or camcorders (JVC, Panasonic, Cannon, Sony, etc.), TiVo (*.tivo), DVDs (*.vob), YouTube (*.flv, *.f4v), *.mts, *.m2ts, *.mkv, etc. to ARCHOS 7 compatible format. You can look through its step by step guide as below.
Step 1: Run Pavtube Video Converter, and click "Add" button to load video files to it
Step 2: Select output format for ARCHOS 7
Click on the pull down menu of "Format" firstly, and then select "Archos", after that, all the profiles for Archos will be listed out, here I choose "Archos 5/7 WMV Video (*.wmv) for example.
Step 3: Specify destination folder
Click on the folder icon at the end of "Output" to specify where to locate the output files.
Step 4: Click on "Settings" button to adjust audio and video parameters
Actually, the default settings can basically satisfy your ARCHOS 7, but if you want to have your own changes, you can adjust all the items like codec, aspect ratio, frame rate, sample rate, bit rate, and audio channel in the following window:
Step 5: Click "Convert" button to start conversion
Once conversion is finished, the output files can be found out via clicking on "Open" button with ease. Afterwards, just enjoy them on your ARCHOS 7 freely.
For more: http://www.pavtube.com/video_converter/
