Echo sound I have the sanyo dvd player model dvd-dx510 and have set it up to a different tv. It has a terrible echo in the sound and I can't remember how I fixed this problem on our old tv. Its connected directly to the tv via av leads with no extra speakers.
ALOT OF TIMES IT IS THE CABLES THAT GO BAD BEFORE ANYTHING ELSE. I HOPE THIS HELPS, IF NOT PLESE LET ME KNOW. IF THIS DOES HELP CAN YOU PLEASE RATE MY ANSWER?
(I GUESS IT IS IMPORTANT FOR THIS SITE)
As different TV configurations demand different setup procedures, figuring out the first step clearly demands paying attention to the type of TV and related setup. You can find a variety of YouTube vidieos about specific TV setups. Additionally, here are some aids:
Make sure it is connected directly to the TV audio output and that there is not a microphone connected to the compilot streaming device. If it has an internal mic or a connected one plus a direct connection via a cable there will be an echoing feedback. Remember to check the set up in the manual to make sure it is connected properly.
Make sure you have the tv volume turned right down as this will cause an echo,also set amp to prologic 2, and set up xover to suit your speakers or go for the THX standard of 80 hrtz and as a rule of thumb set front L,C,R speakers to zero rears to about +4or5 and your sub to -5[ dont know which speakers you have but try setting the subs on board volume to the 10,o,cloak position],also make sure the speakers -,+ are wired the same at the amp and speakers.
The echo you hear is the audio delay between your TV speakers and Bose speakers. Muting (or lowering the volume) on the TV will eliminate the echo. Some TVs have a setting to turn of TV speakers entirely, allowing you to listen to your TVs audio strictly through your Bose system.
I found that the best way to avoid this problem is to mute the television speakers or, if you can, turn off the speakers. There seems to be a very brief delay between TV and theater speakers, causing what sounds like an echo. hope this helps.
