Sony BM-850T Desktop Cassette Transcriber / Recorder Logo
Mike Tillman Posted on Apr 24, 2017
Sony BM-850 microcasette dictator/transcriber.. Using a new tape or an erased tape the pedal and the buttons work correctly. It will stop and start or rewind without delay or overrun. But when I play a recorded tape it delays on stop and rewinds way too far. I can use the same tape... erased it works great but recorded it delays and runs over fron .5 to 2.0 seconds. The rewind will runover about the same. Then I erase the same tape and it operates like it is supposed to. I have adjusted the speed and reverse with no effect. The console buttons do the same thing. Any ideas?
5 Related Answers
A Soveral
  • 566 Answers
  • Posted on Jul 28, 2009
SOURCE: rewinding to listen to recording
You should use the computer with Digital Voice Editor software to have more options when trabscribing. You could then use the transcribing keys to playback your recordings and regulate the velocity of the playback.
Download Digital Voice Editor Version 3.1.03 for Windows Vista/XP/2000.
64 bit version operating systems are not supported, though
javer821
Javier Gonzalez
  • 207 Answers
  • Posted on Jan 07, 2010
SOURCE: Sony BM-147 transcription unit rewind/fast forward problems
Hello just get a really cheap foot pedal replacement at http://www.tvps.com/Products/ECS-Sony-IN-75-Heavy-Duty-Foot-Pedal---Pre-Owned__ECS-PIN-75.aspx
drifterK
Catalin Turcu
  • 4924 Answers
  • Posted on Sep 01, 2010
SOURCE: We have 2 Sanyo Memo
try the local electronic device repair shop ..cause this is not a complicated intervention ..it is either the motor belt that snapped out or broke ..(in this case will not play either ..) or it is just the button or the contact to it ..and it is resolved in a few minutes....
Anonymous
  • 1622 Answers
  • Posted on May 12, 2011
SOURCE: We have a Sony BM-575
Hi,most times,when a Sony BM-575 recorder/dictator malfunctions,what i will advice you to do,is if the Sony BM-575 recorder/dictator is still under warranty,you could simply take it back tothe store for replacement..They are very delicate to handle by any other person.
Or you could simply contact sony tech support..
Also if you can get an expert that can fix it properly ok with that.....
You can check the manual and see if it has a reset button to reset...
That will do...
Anonymous
  • 300 Answers
  • Posted on Jun 27, 2011
SOURCE: need a replacement drive belt
Sounds like you're a very handy type of person with enough courage to disembowel such delicate piece of equipment.
This may be a good place to start looking for that drive belt.
New problem
take it back for a warranty refund and get a different machine
Are you able to erase an tape on a Sony BM-147 transcriber?
No, this unit does not have an erase feature. You would need a magnetict tape eraser such as a BE10.
When i put a tape in to transcribe it sounds garbled. Do you think it could use a cleaning?
1. Try to change the tape speed on your machine. Sometimes that will fix it.
2. Maybe the tape is just old (has been dictated on too many times) and in that case, have the person dictate on new tapes and discard the old ones. They dont last forever.
Hope I could help!
How do I erase tape on sony microcassett
Hold down the 'Erase' button and press the 'Rewind' button. It will erase the tapes as it rewinds.
Tape sound fades out as tape plays.
Hello I can be two possible problem your unit has a bad head or it needs a new pinch roller you can send your unit to service at Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem or you may get a spare is on sale and is complete you end having extra parts and the unit has warranty http://www.tvps.com/Products/SONY-BM-850T-Micro-Cassette-Transcriber---Pre-Owned__SO-P-BM-850-T.aspx
5helpful
Sony BM-850T2 -- Continues after lifting foot from pedal
Hello the reason is you have set as Dictator Press and hold Stop and Reset for more than 2 seconds when your dispay change and show 000 your unit is ready to transcribe your auto back space it will work Normally
Transcription does not work .. foot pedal will not
Hello on the right side of unit is a switch for transcribe make sure is on the on position you are going to see on Deck A only lines on display, put your tape on Deck B is the only side that transcribes if the pedal does not respond you probably have a broken pedal here is one in a great price
Or if you feel better to send unit to service try this.
Foot Pedal & the letter / second button
Hello the SONY BM-147 Does Not have that Letter or secretary function to me is probably the you are using the original SONY FS-75 pedal and is really common the when the pedal brakes it goes to all the way to beginning you can try to unplug the pedal when is rewinding if when you unplug the pedal the unit stop you need to Buy a new Pedal you can find one at http://www.tvps.com/Products/ECS-Sony-IN-75-Heavy-Duty-Foot-Pedal---Pre-Owned__ECS-PIN-75.aspx or go to their site www.tvps.com for more options
Sony BM840 Dictaphone/Transcriber
I have a Soney Transcriber BM-840. 'When I press the erase/rewinder buttons, the tape IS NOT erased. What am I doing wrong?
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
