Epson Stylus CX6400 All-In-One InkJet Printer Logo
Posted on Feb 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I turn on my Epson stylus CX6400, it has the message "error-Printer error-See your documentation and call service if necessary." The only thing the documentation manual says about this error is to locate your locate service rep.
Martin Smallridge
Level 3:
  • Epson Master 419 Answers
  • Posted on Mar 23, 2010
Martin Smallridge
Epson Master
Level 3:
Answers
419
Questions
0
Helped
289784
Points
1120
Do you have any other indicators such as flashing lights or similar?
My guess is that it MIGHT be a "service required" error meaning the waste pads are full in which case this guide may help..
There's a reset sequence you can follow near the end of the article which I'd try... If that solves it then you'll need to deal with the waste pads.. If not, you'll know it's something else and can report back..
  • MARCIAL_P Sep 17, 2010
    Resetting the waste ink counter
    Assuming you have completed your modification you can reset your printers waste counter using this method (This is untested so I can't guarantee it works but reports indicate it should)
    1. You will see big button on your printer like power on (this is on the left
    2. side), black
223helpful
3answers
My epson stylus cx6400 says printer error check documentation and if necessary call service. What could my problem be I have checked the cables all are good
I had the same problem and this worked.
  1. Turn OFF the printer.
  2. Press B/W + Color + Stop button together and hold
  3. Press Power ON button and hold (4 buttons on hold now and don’t release the buttons until you see the light indicator is blinking. A message will be displayed on the LCD)
  4. Release all buttons.
  5. Press the Color button once
  6. Turn OFF the printer.
  7. Turn ON the printer and the protection counter should be resetted
1helpful
2answers
When turning the power on to my Epson CX6400, the following error message comes up: "Error: Printer Error -> SEE YOUR DOCUMENTATION AND CALL SERVICE IF NECESSARY." The little "!" exclamation point...
Sounds like the ink counters need resetting (it happens with other printers as well)
Go here for more info as the prog supports your printer
http://www.ssclg.com/epsone.shtml
Printer reads-"Printer error-see your documentation"... no clue as to what to do.
pull the plug and unplug it again..or load and unload your cartridge..,or change the cartridge you using...maybe the printer don't recognize the printhead..
Error light on
try this site and follow it along
http://er.epson.com:8001/start?TM=false&CMD=iSearch&CB=1886098358&LG=1&TP=NoviceCase&Q1-1-1886170412=1886170410&FI=1&firstQuestionID=Q1-1-1886170412&firstAnswerID=1886170410&category=allinone&model=cx64__&displaymodel=Epson+Stylus+CX6400&referralmodel=Stylus-CX6400&pid=C11C545001
its their support link
Initial Charge message not seen
Sounds as though the printer is defective.
Call or email Epson Tech Support.
Error message displayed on cx6400
Go through the diagnose steps on this Epson site:
http://er.epson.com:8001/start?TM=false&CMD=iSearch&CB=1886098358&LG=1&TP=NoviceCase&Q1-1-1886170412=1886170410&FI=1&firstQuestionID=Q1-1-1886170412&firstAnswerID=1886170410&category=allinone&model=cx64__&displaymodel=Epson+Stylus+CX6400&referralmodel=Stylus-CX6400&restart=yes
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Not workin'
I assume you've checked and done all the basic things like a power down and power up reset and checked to make sure all the ink cartdridges are properly installed and seated.
The user manual discusses your error message and suggests you do the following: Open the scanner unit to make sure any tape securing the ink cartridge holder has been removed; close the scanner unit/ press the ON button to turn off the CX6400, then turn it back on . If the error message still appears, contact your epson dealer or Epson tech support. If so,then you may want to get direct support and information from Epson at this website : http://er.epson.com:8001/start?TM=false&CMD=iSearch&CB=1886098358&LG=1&TP=NoviceCase&Q1-1-1886170412=1886170410&FI=1&firstQuestionID=Q1-1-1886170412&firstAnswerID=1886170410&category=allinone&model=cx64__&displaymodel=Epson+Stylus+CX6400&referralmodel=Stylus-CX6400&restart=yes
Technical Support line_dkblue.gif spacer.gif United States Phone Number:
(562)276-4382
Hours: Mon.- Fri. spacer.gif 6AM-6PM (PT) Canada Phone Number:
(905)709-3839 Hours: Mon.- Fri. spacer.gif 6AM-6PM (PT)
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
