Whirlpool 5"x36" White Bathroom Drop-in  Bathtub Spa Jet Logo
Posted on Feb 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My jacuzzi bathtub plastics pipes underneath are leaking due to being chewed by rats. So if i fill up the tub to the jacuzzi line holes, water leakes through the chewed pipes on to the wood floor underneath. The tub is encased in tile with NO access. Is there a way to plug the jacuzzi line holes so I can use it as just a regular tub?? I dont want to break out the tile right now and pull the tub out to fix the chewed pipes. Thanks, Paul
US Parts Center
Level 3:
  • Whirlpool Master 719 Answers
  • Posted on Sep 06, 2010
US Parts Center
Whirlpool Master
Level 3:
Answers
719
Questions
0
Helped
284301
Points
1972
No there is no solutions for plugging off the jets so the water doesn't go in them. you will have to pull the tub and repair the lines. no access panel just means you have to dig in!
I have a jacuzzi whirlpool tub in my home that has started to leak at the three button control panel. Flooded out the bathroom so I cut a hole in the tile surround and when the pump is running it leak
First thing you need to do is remove some skirting so you can actually see where the water is coming from.
The 3 position control panel would only leak if the water was above it or covering it if it is located in the wall of the tub. That solution would only require the bather to NOT fill the tub quite so full.
IF however the water is coming from another location then that will be noticeable when you are checking for the water leak.
Replacing jet
When you installed the new jet, did you install a new gasket on the wall fitting or use 100% RTF type silicone?
In order to seal a wall fitting that is cracked an leaking, the replacement must have either the gasket or silicone to seal the wall fitting against the wall of the tub or it will leak when filled with water.
Rod
U S Parts Center
I have a kohler jacuzzi tub and many times over the past 5yrs the pump continously trips and the jacuzzi will not start. Any suggestions i have tried to reset the button unplug and plug it, an filled it...
Sound like your pump may have a leak into the electric motor part of it through the shaft seal.
Or it could just have junk stopping up the lines or the pumps impeller. Hair often finds it's way into these things and screws them up!
If it's leaking there will be some water showing below the pump unit.....
Feb 20, 2011 • Kohler Home
I have a new Jacuzzi tub with a Rapid In-Line Heater. When I fill the tub the water the initial temp is 67 degrees. The heater only increases the temp to 71 degrees. What is wrong with the heater ,if...
The bath heater you have is not designed to HEAT water - they only Maintain what you start with.
You need to start the bathtub with the hot water you want. It will only heat about 1-2 degrees an hour.
1helpful
Black spider like material that may come from jaccuzi
Is it greasy, oily spider web type junk? Coming through the pipes, new construction or new tub? Could be from the pump, not that it is leaking oil but it has oil in it from the manufacture of it. I would call the jacuzzi people and tell them what you have and that your kids play in the tub and drink the stuff, ought to get them to move on that one. Ask them if they know what it is and what to do about it? Hope this helps.
6helpful
3answers
Leaking water from bottom
Hello there:
If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub-
Bath tub leaks
Well if its not from drain then it could be from one of the supply valve (hot/cold) it is also possible that its leaking from the overflow drain. this gets overlooked sometimes because of its location. One thinks that water has to be filled that high but one might be surprised how much water gets there when taking a shower or splashing in the tub. There should be an access panel to check the valves and overflow gasket. If not remove the handles and echuns to see if you can see anything.
I HAVE SIX JETS AND A CIRCULATOR, THEY ALL UNSCREW. DO THEY MAKE CAPS THAT I COULD JUST SCREW IN PLACE OF THE JETS AND HAVE A NOIRMAL TUB WITHOUT HOLES. OTHER THAN THE HOLES THE TUB IS OVAL AND SMOOTH ALL...
I have worked on jetted tubs for 5 years and have yet seen a screw in plug replacement for the jet. It would be very expensive to fill the holes and refinish it. You may want to look into tub liners, they to are very expensive. I guess it depends on how long you plan to live in that house. If they are not leaking just use it as a tub and don't use the jets.
5helpful
Leaking pipe in a jacuzzi hot tub
The only product I know of which will do what you ask is an item called Plast-Aid Acrylic and PVC repair kit. Google it and you will find the website. It is about $20. and it works like a charm. good luck
Jan 10, 2009 • Home
Top Whirlpool Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
