Could be the input water pressure is not sufficient. There is a pressure valve inside the machine that will cut off the motor if input pressure is too low or non existent.
Try a different source for the water input.
Testimonial: "I haven't had a chance to try the suggestion but it makes sense. Thank you."
Pulsing is caused by an air block in the hose. Best way to clear it is to hold the trigger open for a couple of minutes and it should clear. Also pull the nozzle forward so it is only on hose pressure and keep trigger open till it clears the air bloc.
