Here it is, I put my clothes to wash in my machine it washes fine but when it its ready to spin its starts to humm, then I have to spin the belt a little to help the process
www.realestate.com > Realestate.com Blog > Articles Sep 16, 2012 - If your washing machine or dryer seems ready to give up the ghost, follow ... When you start your washer, a solenoid-operated water inlet mixing valve ... Afront-loading washer lacks the agitator, instead using the tumbling ... Clothes Remain Wet After the Spin Cycle. 1. .... Bought washer/dryer second hand.
First you need to open the cabinet and remove the boot from the tub to the pump and clear the filter. Try that then run a cycle and post back the results.
motor coupler-to test restart the washer in it's spin cycle, let the washing machine run for one minute, then open the lid and check to see if the tub is spinning. if it's spinning the coupler is fine. if it is not then the coupler needs to be replaced, can be purchased at any appliance parts store. good luck!
I can a very simple part called the motor coupler...you can find the part at www.repairclinic.com. It costs 13.95. I am fixing my washing machine today, as this happened before and was the answer. Goodluck
Check for buildup of detergent/foaming while washing. Check for oil leaks around the clutch area. Could also be the clutch lining is worn out. Replacement parts kit includes all parts
