Try to reset to factory reset through RESET button on device. Normally it's the POWER button. Press and hold the power button for approximately 10 seconds, your device will reboot.
Keep disconnect the car's battery for a longer period of time to ensure that the radio's memory is fully cleared. Be sure to have the car's security code on hand, as it may be required to reactivate the radio after reconnecting the battery.
If none of these steps work, there may be an issue with the radio's hardware or software that requires professional repair. It's best to have a qualified mechanic or car audio technician diagnose and repair the issue.
It sounds like you have already done some troubleshooting by replacing the TCON and main boards, but you are still encountering issues with the TV being stuck in burn mode. Here are some additional steps you can try:
Power cycle the TV: Turn off the TV and unplug it from the power source for a few minutes, then plug it back in and turn it on again.
Check the cables: Make sure all cables, including the HDMI and power cables, are securely connected to the TV and any external devices.
Reset the TV: Look for a "reset" or "factory reset" option in the TV's menu settings. This will restore the TV to its default settings and may help resolve the issue.
Contact the manufacturer: If none of the above steps work, you may need to contact the manufacturer for further assistance. They may have additional troubleshooting steps or be able to repair or replace the TV if it is still under warranty.
Hopefully, one of these steps will help resolve the issue with your TV being stuck in burn mode.
Hi mike harris,
i think your TV is on demonstration mode.
To turn off the demo mode, press and hold the HOME or MENU button on the TV for more than 10 seconds. The messageDemo mode: Off will appear on the screen. NOTES:
If holding the HOME button for 10 seconds does not work, you can also try pressing and holding the CH/INPUTbutton for 10 seconds.
Try to see if any of these four methods will work. Sanyo TVs 1. Press VIDEO MODE or TV/VIDEO button in front panel or on remote 2. Press MENU , choose FEATURE SETUP, then choose either VIDEO MODE or TV/AV, select VIDEO or AV 3. Press TV/AV or INPUT SELECT on remote 4. Press SETUP, choose TV/AV, switch to AV
To turn off the "stuck" pip on a Panasonic tv without a remote, turn off the tv. Then hold down the "Action" button on the front of the tv and press the power button. This will activate a reset and self check of the systems and voila! The pesky pip screen will be gone! This is on an approximately 10 year old regular crt "CT-xxxxx" series tv.
