Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
Posted on Feb 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My vaccuum has no more suction
Please help i don't what to do with my kenmore progressive direct drive, does it take a belt? why does it have no more suction, hapened after i changed the bag.
Rick Rife
Level 2:
  • Expert 414 Answers
  • Posted on Feb 25, 2010
Rick Rife
Expert
Level 2:
Answers
414
Questions
Helped
117166
Points
870
There is no drive belt on a progressive drive vacuum. It is direct drive meaning it is attached via the motor. No vacuum means no air flow somewhere in the unit. Torn bag,Wrong bag, pluged filter under bag.Make sure the opening in the bag is the correct size,too big and it will not seal. Make sure when you close the housing it seals also. No housing seal no vacuum. Kenmore vacuums tend to be plastic housings. Cracks are comon in the wheel housing area. Check there first. Plastic expoxy will work with this fix if so needed.
Ther is no suction and rolar prush is not runing in my kenmore vacume progressive
Remove the rotating brash and check it, something is blocking the suction, probably you need a new belt
My vaccuum lost suction
CHECK THE HOSE TO SEE IF THERE ANY OBJECTS BLOCKING AIR FLOW,ALSO CHECK THE BELT TO MAKE SURE IT ISN"T SLIPPING OR BROKEN.
1helpful
2answers
Kenmore Progressive 100
Check the brush roll ends, make sure they turn freely, if not then replace it. The belt may look ok, but they stretch after a short time and should be replaced.
2answers
Getting suction to use attachments
When the vacuum is in the upright position, it should give you suction thru the hose.
Kenmore progressive vaccuum
Did you replace the hepa filter with a new one? Those filters may not look bad, but after a period of time and use, air is restricted thru them. They should be changed at least once per year.
Top Kenmore Vacuums Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
