Cisco ASA 5505 Firewall Logo
Anonymous Posted on Feb 22, 2010
Checksum verification on compression loader failed causes my ASA5505 to reboot. Any ideas? I have already attempted to perform a factory reset.
Anonymous
Level 3:
President:
  • Master 2,923 Answers
  • Posted on Feb 22, 2010
Anonymous
Master
Level 3:
President:
Answers
2923
Questions
0
Helped
730128
Points
8409
Checksum verification has something to do with the communication of this device.
Since you already perform the factory reset, the only thing that I could think of is that the BIOS (internal component) of this device went bad. That BIOS should be reprogram or replace.
Unfortunately, you need to contact the manufacturer and have them repair it for you. Only the manufacturer can repair this.
Thank you!
My Rca-W101-V2 tablet wont go past the start-up screen.
Part of the difficulty lies in that after performing a factory reset, Windows 10 will then attempt to install updates which followed the original factory provided version of Windows 10. That can be a rather tediously lengthy process if you are expecting simply a quick fix by a reset. Such subsequent updates can involved reboots and some long intervals almost as joyous as awaiting defragmentation to complete on non-SSD equipped computers. It is not unusual to think the entire process has failed when it is actually processing sight unseen in the background. This is a true test of patience. And if there is somehow damage to the backup image being drawn upon ;for the restoration, one may be tempted to drive over the computer in a vehicle. But chances are, you are simply witnessing a restoration for which you would be better off spending half a day elsewhere while it attempts to sort itself out. I wish I could give you an idea of just how long this takes but all I can offer is kiss goodbye the idea it will be measured in minutes rather than hours. A faster alternative? There are rescues via USB drives loaded with Windows 10. But if you have sufficient patience, you might be able to recover simply by using the reset. But don't sit around waiting!
How do I bypass goggle verification after factory reset
  1. Reboot into Recovery mode (hold Home, Volume Up, and Power, releasing Power when you see the device turn on/reboot).
  2. Perform a Factory Reset (press Volume Down until wipe data/factory reset is selected, press Power, scroll down to Yes -- delete all user data and press Power again).
  3. Proceed through the device Setup Wizard until it prompts you for the Google account credentials.
  4. For a Samsung device, save this RootJunky APK onto a USB flash drive, and connect it to the device via OTG.
1helpful
2answers
My nabi dreamtab wont reset why?
There are two types of resets that you can perform on nabi - forced reboot and factory reset. In the unlikely event that your nabi becomes unresponsive, you can easily perform a forced reboot. A factory reset is recommended when slow performance persists or if you want to wipe out all of your personal data and settings from nabi. Forced Reboot: To perform a forced reboot, hold the Power Button down until nabi turns off. When nabi is off, press the Power Button to turn on nabi again. Factory Reset: Caution! A factory reset is a very serious process because it will SYSTEMATICALLY WIPE ALL USER DATA from nabi. A factory reset will return nabi to its original factory settings.To perform a factory reset from Mommy/Daddy Mode, tap All Apps > Settings > Backup & reset > Factory data reset > Reset tablet > Erase everything. Please note: We highly recommend backing up your nabi prior to performing a factory reset. You can back up your music, videos, photos and apps with nabi™ Sync.
How do I perform a factory reset on Nabi Jr. Daughter uncertain her info on it??
A factory reset will wipe all data including installed apps. Make sure the battery is fully charged before beginning this as you could "brick" your Nabi. Here's the video I used with the procedure on it: https://www.youtube.com/watch?v=T-bamfAKvgk
Steps are:
  1. turn it off
  2. hold power and vol + button until menu appears
  3. press vol - to highlight "recovery kernel"
  4. press vol + to select it
  5. press vol - and vol + at the same time
  6. menu will appear use vol - to select "wipe data factory reset"
  7. press power button to select it
  8. press vol - to select "yes delete all user data"
  9. press power button to select it
  10. this will perform a few actions and take you back to the menu from step 6 should already be on "reboot system now"
  11. press power button to select "reboot system now"
  12. the Nabi will reboot and reset to factory defaults
At&t zte990 screen blacks out when making call
This may be due to some software issue.i suggest you to reset your phone that will solve any kind of issues facing with your phone.I have my phone where my display went black, and i performed the below steps. You can even try this
Press and hold the combination of the Power key+ volum up key+ Menu key when the phone is off. When it enters the boot loader mode of teh phone use the volume key to scroll --> select wipe data and factory reset --> select yes and wait till the phone reboots.
1helpful
What causes obd code u110c
U110C-NO FUEL LEVEL BUS MESSAGE
When Monitored and Set Condition:
When Monitored: Ignition on.
Set Condition: No fuel level BUS messages received by the PCM for 20 seconds.
POSSIBLE CAUSES
DTC RESET
COMMUNICATE WITH BCM
PCI BUS CIRCUIT OPEN FROM PCM TO BCM
BCM
TEST ACTION APPLICABILITY
1 NOTE: If a fuel level circuit or performance DTC is set along with P1681,
diagnose the circuit/performance DTC before continuing.
Turn the ignition on.
With the DRBIIIt, erase DTCs.
Start the engine on and off several times. Leave the engine running for at least 20
second each time.
With the DRBIIIt, read DTCs.
Does the DTC reset?
All
Yes ! Go To 2
No ! Refer to the INTERMITTENT CONDITION symptom in the
Driveability category.
Perform POWERTRAIN VERIFICATION TEST VER - 1 - NGC.
2 Ignition on, engine not running.
With the DRBIIIt, attempt to communicate with the BCM.
Can communication be established with the BCM?
All
Yes ! Go To 3
No ! Refer to the Communication Category and perform the appropriate
symptom related to no communication with BCM.
3 Turn the ignition on.
Using the DRBIIIt, read the Fuel Level parameter in the PCM.
Does the DRBIIIt display a fuel level value?
All
Yes ! Replace and program the Powertrain Control Module in accordance
with the Service Information.
No ! Go To 4
287
DRIVEABILITY - NGC
4 Turn the ignition off.
Disconnect the PCM harness connectors.
Disconnect the BCM harness connector.
CAUTION: DO NOT PROBE THE PCM HARNESS CONNECTORS. PROBING
THE PCM HARNESS CONNECTORS WILL DAMAGE THE PCM TERMINALS
RESULTING IN POOR TERMINAL TO PIN CONNECTION. INSTALL
MILLER SPECIAL TOOL #8815 TO PERFORM DIAGNOSIS.
Measure the resistance of the PCI Bus circuit from the BCM harness connector to the
appropriate terminal of special tool #8815.
Is the resistance below 5.0 ohms?
All
Yes ! Replace BCM in accordance with the Service Information.
No ! Repair the PCI Bus circuit between the PCM and the BCM for an
open.
__________________
How to counfugre asa 5505 cisco Router
Use the Cisco ASDM or SDM software, that will give you an easy graphical interface to configure the ASA. One of them would have been shipped with the device.
Don't forget the ASA has to pre-configured, just a simple config. Have HTTPS enabled and telnet/SSH helps as well if you dont have a serial port or the console cable.
Cisco's website will give you quite a lot of info for free...
1. Change your PCs default gateway to your firewalls' internal IP
2. configure the nameservers on your ASA
Then internet will work fine.
Top Cisco Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
