Optics Logo
Posted on Feb 22, 2010
Nikon traelelite II 7x20 7.1 101853 tried to open and pulled the cap off one side of the lens and need to ge it back on rubber piece and plastic piece i have. I need to get the plastic piece back inside the rubber piece. help thanks
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
415
Points
Nikon will repair for 20.00
http://support.nikontech.com/app/answers/detail/a_id/14461/related/1/kw/binoculars/r_id/116678
Anonymous
Level 1:
New Friend:
  • Contributor 43 Answers
Anonymous
Contributor
Level 1:
New Friend:
Answers
43
Questions
0
Helped
22211
Points
58
Do you mean that you have taken off the rubber eyecup from the eyepiece itself? That can be fitted back on using a contact adhesive such as Selleys KwikGrip. If this is not what you mean, post again.
Remove stuck rear lens cap
The first thing I would try is using one of those rubber pads that are used for removing stubborn lids from jars. If that dose not work, I would use the fact that the Nikon rear lens caps are made out of soft plastic to my advantage. If you have a Dremel rotary tool with a disk cutting tool, you may be able to CAREFULLY and slowly cut away the lens cap. You didn't say which lens this is, but since with most lenses the telephoto position moves the rear element away from the back of the lens, I would set the lens to telephoto before starting to cut. I would start by cutting through the back of the lens cap. Cut a little at a time and try to take off the cap. Proceed slowly periodically trying to remove the cap. Hopefully, the pressure will be relieved and the cap will release before it becomes necessary to cut across the lens flange. When you are done, I would carefully clear the lens of any debris.
I recently bought a sigma 28-80 3.5-5.6 ii macro for my nikon d5300, the lens will not mount to the camera body. I noticed some plastic pieces had broken off the backs of lens. Have I purchased a defective...
Here are 3 pictures of a Sigma lens for Nikon. Your lens should look about the same. Could be a little less connection points, but notice there is no plastic.
e1f0e696-b90c-4dac-882d-bdba89e8d9e8.jpeg 9e6c062e-9233-4de8-bf2b-75c0e0b3414f.jpeg 9c9661f0-e5a8-4b72-a302-fa4b2c3ce532.jpeg
Feb 16, 2014 • Cameras
My 18-55mm lense zoom bit is loose and keeps getting jammed when i try use the zoom, help?!
Brand New Nikon D90, Nikon D300, D80 For Sale.
Our PRODUCT are accompany with letter of authenticity and has 1 Year international warranty and information warranty
Please contact us for more information and purchase inquiries:
Contact: Mr roy steve
Email:[email protected]
MSN TO CHAT:[email protected]
Company website:www.electronicsystemltd.page.tl
Here is our price lists below
Brand new Nikon D90 :
D90 Body
18-200mm f/3.5-5.6G ED AF-S DX Zoom-Nikkor Lens,
EN-EL3e Rechargeable Li-ion Battery,
MH-18a Quick Charger,
EG-D2 Video Cable,
UC-E4 USB Cable,
AN-DC1 Strap,
BF-1A Body Cap, DK-5 Eyepiece Cap,
DK-21 Rubber Eyecup,
BM-7 LCD Monitor Cover,
Accessory Shoe Cover,
Nikon PictureProject Software,
Nikon 1 year Warranty
Brand new Nikon D80 :
D80 Body
18-55mm f/3.5-5.6G ED AF-S DX Zoom-Nikkor Lens,
EG-D2 Video Cable,
UC-E4 USB Cable,
AN-DC1 Strap,
Brand new Nikon D300
box content:
D300 digital SLR camera Body
18-200mm F/3.5-5.6G ED-IF AF DX VR Lens
Rechargeable Li-ion Battery EN-EL3e
Quick Charger MH-18a
Video Cable
USB Cable UC-E4
Strap
Body cap
Eyepiece Cap DK-5
Rubber Eyecup DK-21M
LCD monitor cover BM-6
PictureProject CD-ROM
Weight: Approx. 830g without battery, memory card, body cap, or monitor cover
WE OFFER FREE SHIPPING FOR THOSE THAT IS BUYING UP TO SIX UNITS. AT THIS TIME YOU BUY 3 ITEMS AND GET ONE FOR FREE.
Happy organisation , Happy buyers.
Thanks
3answers
D40 Nikon
i have the same problem..only it seems mine has been caused by a piece of plastic off my lens somehow falling behind the shutter and impeding its use.I wouldn't recommend you poking around the shutter but you could remove the lens to have a look if the optics is damaged.Bringing it to an authorized dealer might be the best way to go !
WONT WASH OR SPIN
It needs a drive coupler for the motor/transmission.
Unplug machine. Just lean the machine back, pop the two clips on the pump and put it to the side. Take the two screws out of the motor clips (usually 1/4 inch), and pop those clips off. Motor will come off. You will see the 3 fingered white piece on the motor shaft and one on the transmission shaft. There is a rubber coupler that connects the two. Replace which ever white plastic piece is broken, or the rubber piece if that is it. Make sure not to bang the white plastic piece too far onto the shaft. The shaft should go flush with the white plastic part facing you.
Put motor and pump back together and plug in motor. You should be good to go.
http://www.youtube.com/watch?v=WLPGs2UMUJc
10helpful
Changing front headlight bulb, directions?
1. Drivers Side. This is the easiest to get to. After opening the hood, right behind the lamp housing there are (2) rubber caps. The outside cap contains the low beam/day running bulb and the inside cap contains the high beam bulb.
a. Both bulbs are replaced the same way. Remove the rubber cap, these caps are soft and pliable but when you grab the edges to pull them off, they feel rigid. This is because the rubber cap is pressed over a hard plastic flange so when you squeeze and pull, it can be difficult to remove. If you can’t get a good grip to pull them off -
b. (Tip) There (2) clips on the headlamp housing, one is in plan view to the left and the other is under the fender just to the right top of the housing. It’s a little difficult to get to and you may need a flat head screwdriver to pry it up. Pull up on these clips and they will release the housing, but you cannot remove it. This will allow you to pull the housing out a few inches and you can see the edges of the rubber caps.
c. Using a flat head screwdriver, just gently pry the cap, once it starts coming off you can remove it with your hand. Reach in and grab the bulb assembly and turn it about ¼ corner turn “counter” clockwise and it will come out.
d. Remove the power wire harness that is clipped on.
e. Snap the new bulb into the power wire harness (DO NOT TOUCH) the new bulb with your bare hand!
f. Gently place it the bulb assembly back in the housing, turn ¼ turn clockwise, it will snap into place, replace the rubber cap, push the housing back into place and press the housing clips back down.
g. NOTE: Always put the rubber cap back on, it helps to keep moisture out of the housing.
2. Passenger Side. This is the hardest to get to. Remove the air cleaner cover and filter or you won’t be able to reach the back side of the housing. The instruction on how to remove these items should be in your owners manual.
b. (Tip) There (2) clips on the headlamp housing, one is in plan view to the right and the other is under the fender just to the left top of the housing. It’s a little difficult to get toand you may need a flat head screwdriver to pry it up. Pull up on these clips and they will release the housing, but you cannot remove it. This will allow you to pull the housing out a few inches and you can see the edges of the rubber caps.
1helpful
2answers
Lost Nikon Travelite ex eye piece
I'm supposing by eyepiece you mean the rubber or plastic eyecup. The eyepiece is the whole unit that contains the lens. Nikon has a service center in many countries. If you have one in your country then they can order the part. I have ordered from Nikon. They find the part number if you tell them your model and can email you an order form. Alternately Binoculars.com is very good to deal with as is Adorama Camera in New York. Both will sell internationally.
6helpful
4answers
Nikon d90 lens plastic mount broke
I feel for you. exactly the same happened to me but i was looking to upgrade lens so i used it as an excuse.the piece is called a bayonet. what lens is it, is it the kit lens. my lens was unfixable so  am afraid as the mount is plastic the whole lens is a right off, if it was a metal mount it would be worth fixing. sorry
2answers
Lens canon 28-135 IS
Need to open Lens?
1. Front Lens Cap- press the two side taps in and pull out.
Rear Lens Cap- twist and pull out.
2. Remove and Repair: Small Phillip Screwdrivers, gloves and mask.
From the rear, the electrical contacts- remove all those
screws. Some screws are locked with clue. Pinch black
plastic ring that is part of those contacts and gently remove out.
Don't brake the electrical contact ribbon cable.
Good lock.
[email protected]
at
Top Nikon Optics Experts
john h
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Nikon Optic Expert? Answer questions, earn points and help others
