I followed the procedure to reset the cartridges of the Canon MX310, but without success. The light with the symbol of lightning continues to flash and remains the U051 code in the display. After following the procedure, the light stays green and does not change to yellow. Thanks in advance. Alessandro.
SOURCE: Canon MP 145 ink reset
If i am not mistaken error E4 is printer has NO INK. Check the cartridges first.
SOURCE: reset Ink levels for canon mx310
You could just turn the ink refill monitor off.
Open the Windows Start menu, open the "Canon Utilities" folder, open the "My Printer" folder, open "My Printer", click on "Printer Status", go to the "Options" menu, unselect "Enable Status Monitor".
You should be able to tell when your ink is low, because the color will fade.
SOURCE: flashing green and yellow lights
You need to count the number of flashes to diagnose the error. Then go here and type error lights in the search box. You';; be able to follow the appropriate code to a solution.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: my canon mx310 alarm light will not go off after i
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
First thing i would look at is the film that runs directly behind the print head i would think it is dirty. just turn on printer and get print head to the middle and turn off machine, gentle move print head to one side and gentle clean the film strip with a cloth with a little metho on it, move print head to other side and clean other part of ****.
i reckon that will fix your problem its a common problem they tend to get a bit of grease on the timming ****. Thank you Sir, Have a nice day.
Testimonial: "yellow alarm ligt remains on after trying to rset and clean film behind print head"
SOURCE: alarm light on and u051 error mx310
I get to the Service Mode but then the orange light just keeps blinking 5 times in a row and never goes solid. I've tried pressing the Stop/Reset 3 times with 3 sec intervals, holding down for 5 secs, for 10 sec, and 20 sec, holding down for 3sec and then releasing for 3 sec (3 times....) and the orange light never changes from it's 5 blink cycle. Any ideas?
Hi alessandro_l, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Did you follow both of the recommended procedures shown in the question here: http://www.fixya.com/support/t5447304-ca...
