Removal
1. Disconnect the battery ground cable.
2. Drain the cooling system. For additional information.
3. Remove the accessory drive belt.
4. Raise and support the vehicle.
5. Disconnect lower radiator hose from the water pump lower tube.
6. Remove the engine mount nuts.
Lower the vehicle.
7. Remove the cowl extension panel. (Thats theone with the wiper arms go through).
8. Disconnect the water bypass hose and the heater hose from the water pump outlet tube.
9. Remove the water pump outlet tube bolt and position the tube assembly out of the way.
10. Install the lifting eye to the exhaust manifold.
11. Attach engine lifting equipment and raise the engine 127 mm (5 inches).
12. Remove the bolt and the accessory belt idler pulley.
13. Remove the bolts and the generator support bracket.
14. Remove the four bolts and the water pump pulley.
15. Remove the water pump. Remove the five nuts. Remove the five studs.
Remove the four bolts. Remove the water pump, lower tube and gasket as an assembly.
SOURCE: lower radiator hose connecting tube to water pump.
remove the radiator hose remove the two bolts that hold the tube on and buy new tube and replace is in reverse order.
SOURCE: power steering pump on a 2001 ford windstar
There is a special tool for that. It should be available at most auto parts stores.
SOURCE: i have a 2000 ford windstar no heat still
the problem (which is all to common on Windstar and Explorer) is the air temperture control blend door actuator motor is defective, this motor is what moves a door that gives hot, cold or a blend of hot and cold air blend to give u the desired outlet air temp.
SOURCE: 1999 Ford Windstar-Will Turn over but won't start?
fuel pressure regulator could hav failed-located by engine or the ignition module may not be workin-by dist area try not to be a parts replacer-buy a repair book
SOURCE: 99 Ford Windstar. Not getting any power to the fuel pump
first check the fuse if it is good then check for power at the relay
