The 2488 requires a start point and end point in order to master down. The start point, by default is zero (the beginning of the song) so you will NOT have to create one, HOWEVER, you MUST provide an end point. The end point is wherever you wish the song to end, so, roll the BIG wheel to the end of the song, then, press LOCATE SET and OUT simultaneously. You have just now marked your out point and thus it will master the whole song. NOTE: If your song is 4:23, then the out point will be/should be a bit longer (a second or two- or even more- that's up to you) than that depending on where the song/music actually begins after the zero mark, therefore, make SURE you roll the BIG wheel enough to encompass the WHOLE SONG. The counter will reflect the time/length as a result of how far you roll the wheel. I hope this helps. One last note, do ALL this at the MIXDOWN prior to MASTERING.
