Konica Minolta bizhub 350 All-In-One Laser Printer Logo
Posted on Feb 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bizhub 350 Hi how do you setup scan to email on the bizhub 350 is there any site that i can go and get info
  • 1 more comment
  • Anonymous Jul 01, 2008
    Could you please spell out this process a little more specifically? Where do I go?
  • Anonymous Mar 13, 2014
    can print but cannot scan via bizhub 350
    bizhub c220 email setup
Anonymous
Level 2:
Champion:
  • Expert 214 Answers
  • Posted on Feb 29, 2008
Anonymous
Expert
Level 2:
Champion:
Answers
214
Questions
0
Helped
192348
Points
268
Use web browser, go your 350 ip address log in as admin, in network setting fill smtp server address and also you have to put email address for the printer and maybe its required to fill admin email also. and should work.
Bizhub c450 stuck on scan-to-fax
Did you set it up to scan to email. info such as authentication, smtp server, valid email address use the copier web page to install this info.
What driver do i use to scan using windows 7 for konica minolta bizhub 350 just upgraded computer and it won't scan now prints ok
I believe you must install the software from the bizhub disc and if that does work you can set it up to setup it to your email as a pdf
Can get LDAP search working on BizHub 350 Multi function copier
the smtp serwer wos chench u nead to setup scan for email whit new seting of smtp
Hi, I just took over a BizHub 350. Whenever I try to scan to a new email address, it doesn't go through and I get the error message "EA3226". Whenever I try to scan and email to an existing email...
The scan-to-email may have been set up originally to utilize the old email server, using the old domain as the conduit for sending the scans through your network.
You may have to load the driver onto the new email server, or the main network server itself (which would then allow you to scan to emails with any destination as it is using the networks connectivity to deliver the emails, not the email server).
Then you can set up as many new user accounts as you want.
Minolta Bizhub C353 fails scan to emails
Hi mmarsh1212,
When you say the bizhub fails Authorization, do you menat it fails Athentication?
If so, and I pressume your technician knows what he's doing, you have an issue with a password. I suggest you create an address for the bizhub on your email server and then re-setup the scanning to email credentials via the web browser direct to the machine.
Let me know if you need help with doing this.
Regards
Taminol
2helpful
2answers
Ocr scan for Bizhub C450
according to what I read on the C450 biz hub, in order to do OCR you need to use the option that scans to SMB, that sends the scanned documents to your computer on the network. You can then process the documents on your computer with the OCR software program so you can edit the finished documents. I did not see anything that indicated the Bizhub had OCR software capabilities built into the unit. Regards, rcampsr
Bizhub 350 error code EA3226 when trying to scan to email
I changed the SMTP address from a name to an IP and that resolved it for me.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
