House I bought has a jacuzzi tub but the air push switch is not hooked up. Looking around through the small access panel but I can't see anywhere that the other end of the hose should connect to. Typically what type of connection does this hose go to ? Is it on the pump body ? I can't see any port on the electrical junction box but there are two small unmarked flanged openings on the side of the pump itself.
SOURCE: jacuzzi tub air push swith not hooked up
It does hook up to the pump/motor there should be a friction fitting that the hose fitts over there is a square like box sitting on top of motor this is where i would look for the hook up (should be in the area of the pump/motor electrical cord) . I hope this helps. Thanks for using FIXYA. Have a great week.
SOURCE: I need to purchase the air hose that connects to
www.maax.com/Upload/guides/fr/000_10050073_0305.pdf
manual above.
http://www.uspartscenter.com/airswitchactuatorairswitchbuttonplug.aspx
link above is for air hose and switch
