Jabra BT160 Wireless Headset Logo
Anonymous Posted on Feb 21, 2010
Jabra bt160. fully charged, unit will not turn on?
Rod Wallberg
Level 3:
  • Master 494 Answers
  • Posted on Feb 21, 2010
Rod Wallberg
Master
Level 3:
Answers
494
Questions
Helped
171898
Points
1170
On my unit and it is older, I have to hold the button for a bit before it comes on. Should beep in your ear..
2helpful
How do you put the device into discovery mode
Before you use your Jabra BT160, you need to pair it with your mobile phone. 1. Put the headsetin pairing2 mode Make sure that the headset is on. Press the answer/endbutton and press the volume up (+) button at the same time, until asolid blue light comes on. 2. Set your Bluetooth phoneto ?discover? the Jabra BT160 Follow your phone?s instruction guide.This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menuon your phone and selecting the option to ?discover? or ?add? aBluetooth device 3. Your phone will find the Jabra BT160 Your phonethen asks if you want to pair with it. Accept by pressing ?Yes? or ?OK?on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros).Your phone will confirm when pairing is complete. In case ofunsuccessful pairing, repeat steps 1 to 3.
USER GUIDE
2helpful
I do not have manual for jabra bt160 how do i connect to phone
Wear it how you like it 4
5
English
The Jabra BT160 is ready to wear on your right ear. If you prefer the left, gently flip and
rotate the earhook 180°. (See fig. 2 )
For optimal performance,wear the Jabra BT160 and your mobile phone on the same side
of your body or within line of sight.In general,you will get better performance when
there are no obstructions between your headset and your mobile phone.(See fig.5 )
Answer a call
Tap the answer/eend button on your headset to answer a call
End a call
Tap the answer/eend button to end an active call
Reject a call (DDependent on your phone supporting this feature)
Press the answer/eend button when the phone rings to reject an incoming call.
Depending on your phone settings, the person who called you will either be
forwarded to your voice mail or hear a busy signal
Make a call
• When you make a call from your mobile phone, the call will (ssubject to phone
settings) automatically transfer to your headset
Activate voice dialing (DDependent on your phone supporting this feature)
Tap the answer/eend button. For best results, record the voice-dialing tag through
your headset. Please consult your phone ’ s user manual for more information about
using this feature
Redial last number (DDependent on your phone supporting this feature)
Adjust sound and volume
Press the volume up or down (+or – ) to adjust the volume (See fig. 1 )
How to...5
1. Put the headset in pairing 2 mode
Press the answer/eend button and press the volume up (+) button at the same time,
until a solid blue light comes on.
2. Set your Bluetooth phone to ‘ discover ’ the Jabra BT160
Follow your phone ’ s instruction guide. This usually involves going to a ‘ setup,’
‘ connect ’ or ‘B luetooth ’ menu on your phone and selecting the option to ‘ discover ’
or ‘ add ’ a Bluetooth device.** (See example from a typical mobile phone in fig. 4 )
Pair it with your phone 3
English
Turn on your headset 2
Press the answer/eend button to turn on your headset
Press and hold the answer/eend button to turn off your headset
Charge your headset
Make sure that your Jabra BT160 headset is fully charged before you start using it. Use
the AC adaptor to charge from a power socket. Connect your headset as shown in fig. 3.
When the LED is solid blue, your headset is charging. When the solid blue LED turns off,
it is fully charged.
The Jabra BT160 is easy to operate. The answer/eend button on the headset performs
different functions depending on how long you press it.
Instruction:Duration of press:
Tap Press briefly
Press Approx: 1 second
Press and hold Approx: 5 seconds
Getting started
Your phone then asks if you want to pair with it. Accept by pressing ‘ Yes ’ or ‘ OK ’ on
the phone and confirm with the passkey or PIN 3 = 0000 (44 zeros).
Your phone will confirm when pairing is complete. In case of unsuccessful pairing,
http://www.jabra.com/Sites/Jabra/UK-uk/support/Pages/JabraBT160.aspx
It is all in there www.jabra.com
ARTGIRL
1helpful
Jabra BT160
The default Jabra password seems to be 0000
Give it a try - it may work
Good luck
2answers
CHARGING My Jabra bt160
I think something's goofy with these headsets. I bought 2 of them recently (one for me and one for my g/f). Within a week or so, she told me hers just "died" - and she couldn't get the blue light to come on when it was plugged into the charger.
Mine acted dead too, just a day or so before she told me about her problem. On mine, I think I just held down the "volume down" button and the main button at the same time for about 15 seconds and it appeared to "reset" it. That apparently didn't work for hers, but oddly enough - after a few days, we plugged it into my charger and it started working again!
2helpful
3answers
My Jabra BT160 won't connect to my Nokia 6103 why?
hold the on/off button and the + button for 2 min. If you fail at the first time. Try again, until you see the blue solid light. Search again in your phone, you should see Jabra bt160. Enter 0000 at the passcode. Good luck
2answers
Jabra bt160
hold the button down for a long time
Top Jabra Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
